Results 1 to 12 of 12
    Default Wolfkatz TFFR and SFFR fuel rail install *with pics*
    Well, this weekend I had a chance to play with some of Wolfkatz's new fuel rails. I was testing out their brand new top feed rail to see if it would clear the Alltrac engine hook (they had to make a special side feed rail for this). Turned out to be no problem at all.
    I can't comment enough on the quality of the Wolfkatz parts. They include everything you need for the install, all bolts and fittings, and a detailed instruction set. Customer service is absolutely awesome too.
    Here's a cool comparison pic. From top to bottom: Wolfkatz TFFR, ST165 stock TFFR, Wolfkatz SFFR, ST185 stock SFFR.
    Here's some pics of the TFFR with the OEM FPR installed. Clears with plenty of room.
    TFFR in position
    Wolfkatz engraving
    A closeup
    The SFFR
    Compared to the stocker
    And the SFFR in preliminary position
    The SFFR isn't completely installed yet. I hope to get some finished pics up very soon.
    I learned a few things installing this rail for next time. The injector hold down plate need to be modded. I used a dremel and cut off the end that attached to the fuel supply hose. I also cut off the peice on the supply hose that bolted to this plate. It is also a good idea to trim a tiny bit off of the other end too. The spacers are a little tricky to deal with when you install the rail in place. Best bet is to tighten the fuel supply hose up first, and make sure that it doesnt get squeezed under the hold down plate. Then you can install the spacers without worrying they'll drop and land on the xfer case which is a nightmare as most alltrac owners know. I had to move the position of the cold start injector hose around to get it to fit, but it did in the end.
    For those of you following my personal plans...
    I've reverted back to the stock injectors. These once are cleaned and balanced and within 2cc of eachother. I am going with the wolfkatz rail so taht when I raise the fuel pressure above stock to get more out of these injectors, I won't have a massive pressure drop (the drop increases with pressure if i understand correct). This should allow me to run a safe injector duty cycle, and still be able to hold 275whp, if i get there. I will also be doing a race gas tune most likely as well.
    Hope you enjoyed the pics!
    As always great informaiton Chris.
    2004 Acura RSX
    2009 Toyota Rav4 Sport
    And one last one with the hold down plate installed. You can see the spacers there that I was talking about
    Hey Chris.
    get me one of those bitches.
    Chris:
    Why not stay with the extra cushion in the 550's? I would assume that with the SMT6, you should be able to tune them to run well.
    luni. talk to garrett. he's the man.
    Quote Originally Posted by G-man
    Chris:
    I had some serious trouble getting my car to run on them. For whatever reason, the car simply wouldn't run. I could start, then it would promtly die after ~1 second. Couldn't alter fuel pressure, or play with the SMT6 to change it. I can't explain why it did this, I had everything hooked up properly. The injectors were the only thing I changed and it hasn't run since. So at least for now I'm going to stick with these injectors to at very least get it running again. I needed to take a few steps back...so I'll start by tuning on these. If I run out of room on them, I still have my 540's to give another shot.
    hmmm....strange. Good luck.
    I just thought of something. Any chance those injectors are high and not low impedence?
    Nope, here's the test printout: http://www.celicatech.com/imagearchi..._flow_test.jpg
    Strange indeed. If it still won't start with the stock injectors, then I'll know something is up.
    Chris,
    Thanks for the positive comments and the pictures. If we can help any of you out, feel free to look us up (email is the best).
    Take it easy,
    It was more of a joke Chris.
    I dont need one yet.
    Yet... lol.
    Wolfkatz those rails look very nice though. Very top notch stuff. Im impressed.
    Keep us updated, because this is in my future.
    2007 Mazda RX-8 GT
