Results 1 to 12 of 12
    Default Part Number request
    Aaron/Tracy I need the part numbers for a couple things.
    I need the following:
    Cold Start Injector gasket
    Turbo hardline to turbo gasket
    Turbo hardline to oil pan rubber line
    93 celica alltrac spark plug wires (the black ones - as far as I know theyre the same as the MR2 ones but theyre black instead of red)
    Fuel Rail insulators (the seals that go on the outside of the tips of the fuel rails to seal them to the engine side)
    Any seals associated to a 93 throttle body mounting to the intake manifold (theres the throttle body inlet, so if theres a seal there I need that, and the seal between the throttle body and the intake manifold)
    Also, on the same idea as the celica spark plug wires, can you guys get a TRD wire set for the celicas, that are black? If so, whats that PN?
    I might have more. Lets start with that.
    Oct 2010
    Eugene, Or
    Luni,
    TRD does not list a wire set for the alltrac. I am not sure what if any differences there are betwen the MR2 wires and the alltrac. I am thinking there is more than just color. I will order a set of alltrac wires in and check the diff's if any and let you know. As for the other items.........
    90919-21524 CORD SET, 80.54(alltrac wires)
    22271-88381 GASKET, T 4.58 (throttle body)
    90561-08032 SPACER 1.39 ea. X 3
    15471-88580 GASKET, T 4.94 (turbo hardline gasket)
    15491-88380 HOSE,TURB 41.68
    23293-88381 GASKET, C 4.69 (cold start gasket)
    I stock everything except for the wires.
    Tracy
    Tracy, can you add front balljoints for a 2000 Celica GTS to my parts list request?
    Oct 2010
    Eugene, Or
    Here's the ball joint info. I received the alltrac wires last night and they seem to be the same except for the coil wire and ofcourse color. The coil wire on the MR2 wires has a 90 deg. connector at one end and straight at the other. The alltrac wires have 90's at both ends. There are a couple of options, try to make the alltrac wire work, re-use your old one, or buy just the coil wire from an MR2 set. The MR2 coil wire runs $9.77.
    Thanks,
    Tracy
    43330-09230 JOINT ASS 44.36
    '91 T-Top N/A MR2
    Nobody has been able to find me TRD plug wires...discontinued AFAIK. They are MR2 only as far as the parts dept goes, but really, fit on either as long as you don't have a top mount IC.
    1994 ST205 WRC
    Oct 2010
    Eugene, Or
    I even check TRD Japan and don't show a listing. The MR2 wires would work, the only difference is the coil wire.
    Tracy
    '91 T-Top N/A MR2
    Got a PN for the TRD wires for the celica?
    FYI they don't make TRD wires specifically for the Celica. The MR2 ones will fit, but they have a handle [loop] on the top of each wire that has to be cut off if used with a TMIC.
    Yeah, I was referring to TRD MR2 wires. They are red, have the handle/loop on them. Everywhere I have tried has them discontinued. So now I use regular MR2 wires because they are red.
    1994 ST205 WRC
    Everywhere I have tried has them (TRD MR2 wires) discontinued.
    They are indeed discontinued, but Toyota still has inventory in US warehouses. There are two styles. Part number PTR04-17901-01 is for '91-'92 MR2 Turbo, and is has the fat distributor terminals that press-fit into the distributor cap, same as an ST185 through 1991. PTR04-17920-02 is for '93+ MR2 Turbo, and it has the smaller distributor terminals and the plastic clips that hold the wires to the cap, same as a Gen3 does, or a '92 or '93 ST185. Prices, of course, are on our website. Paste the part number into the Search By Part Number bar on the left side of the main page (do not select a vehicle) and let 'er rip.
    Placed order 26029217. Make sure it goes out with love guys
    Thanks for the order! I will include a couple of extra commas for you too, if I can find 'em, since we don't have any "love guys" around here for you - although Tracy did show some interest in playing that role.
