    Default All Trac Handling FAQ
    This is a repost of a thread that CMS-GT4 put up about 5 years ago. There's good info in it.
    I wanted to make a thread for the suspension setups of the alltrac.
    Post your track alignment settings. Maybe we can use this thread to come up with solutions for suspension for track and rally use.
    Here is an article on the stock handling of the st185.
    Goes into alignment settings as well.
    http://www.whiteline.com.au/articles/RH ... aGT4_a.htm
    Thread on seting up a serious course car. More on hows and whys to setup your alltracs handling.
    http://alltrac.net/phpBB2/viewtopic.php?p=187915#187915
    Also here is a link that explains alignment better.
    http://www.familycar.com/alignment.htm
    Here is a tech on doing your own alignment.
    http://corner-carvers.com/forums/showth ... ge=1&pp=40
    The whiteline article claims that the st185 could use more + caster.
    I would like to post up the 185 suspension workings and look at how other mcpherson strut type cars adjust the caster. We may be able to develop a solution to get everything worked out right.
    Here are the Whiteline sugested track settings for the 185.
    Camber: (F) -1.5 / (R) -1.0
    Toe (F) 0 / (R) 1mm out
    They later updated from camber to-2.0 for racing. Some board members that autox run up to -3 camber.
    I plan on trying out these settings when I get the car running again.
    Parts that seemed to help:
    Cusco front underbrace. (Helped firm up steering)
    Whiteline rear sway bar. (Excellent)
    Whiteline bushings. (Made the car feel more planted and controlled)
    Adjustable sway bar links.
    Aluminum rear diff mount.
    Parts I will test and install:
    Strut tower bars.
    J-speed chasis mounts. (http://bulletproofautomotive.com/catalo ... hp?ID=1242)
    On a note of handling. No matter how much $$ you throw at your suspension, unless you upgrade to a wider gripier tire, your throwing money away.
    Another note, lsd is another important aspect to this cars handling, but we will cover the suspension chasis part of it in this thread and touch on the handling aspect of lsd some.
    Here is a link to the lsd thread.
    http://alltrac.net/phpBB2/viewtopic.php?t=5570
    Here is a link to the wheel/tire size thread to help in choosing a wide enough wheel/ tire for you budget or needs.
    http://alltrac.net/phpBB2/viewtopic.php?t=1327
    Weight reduction thread.
    http://www.alltrac.net/phpBB2/viewtopic.php?t=863
    Good artilce on brakes. A very important apsect to handling. And braking parts.
    http://www.stoptech.com/tech_info/wp_wa ... disk.shtml
    http://alltrac.net/tuning/brake.html
    http://www.rocketeerperformance.com/cat ... 637616491b
    Threads on braking:
    http://alltrac.net/phpBB2/viewtopic.php ... re&start=0
    http://alltrac.net/phpBB2/viewtopic.php ... brake+bore
    Link to many alltrac related suspension parts.
    http://alltrac.net/tuning/suspension.html
    Here is another link on handling. This one is for the gtfour, and goes a little into strut selection/adjustment.
    http://gtfour.supras.org.nz/chassis%20dynamics.htm
    Here is a good link to a do-it-yourself alighnment tech.
    I am going to research this more, so I can do my own alignment to save money, and set it up properly so I can take it to track and autox.
    Some links for handling in other awd cars that may apply to our car. I would like to go to a test and tune autox and try out some of these items.
    http://forums.nasioc.com/forums/showthr ... did=203801
    A link that has a good explination of unsprung wieght and how various suspension works.
    http://www.chris-longhurst.com/carbible ... bible.html
    A good link about everything for suspesnion tuning. Explains what all the bits do even tires.
    http://www.turnfast.com/tech_handling/handling.shtml
    Cusco Underbrace review.
    http://www.alltrac.net/phpBB2/viewtopic ... highlight=
    OEM torsen lsd threads.
    http://alltrac.net/phpBB2/viewtopic.php?t=2652&start=90
    http://alltrac.net/phpBB2/viewtopic.php?p=176216#176216
    A thread about using a rav4 gearbox for a lower final drive and that the final drive is only affected in the gearbox.
    http://www.alltrac.net/phpBB2/viewtopic ... 884#215884
    Suspension and chassis development link from National ProSolo champion:
    http://farnorthracing.com/autocross_secrets.html
    A good read on suspension functions and types.
    http://www.carbibles.com/suspension_bible.html
    92 All Trac-Daily Driver
    Member smog7 is on a distinguished road smog7's Avatar
    Nov 2006
    central coast, california
    Is it ok to add more links?
    motoiq's series on handling has specific tips for mcPherson strut suspensions
    http://www.motoiq.com/magazine_artic...ion-guide.aspx
    dented fender, blown struts, leaks oil, she's a beaut!
    If you've got more links, knock yourself out.
