Celica All Trac and GT-four Original Toyota Part Numbers
Here are some of the most common part numbers you will need for maintaining your Celica All Trac. There are also some part numbers of GT-four parts that you can swap into your All Trac for performance. If you have more part numbers please add to the post.
ST165 Turbo Intake
AirFlow Meter to 1st Metal Peice 17659-88381
Metal Piece to Turbo 17882-74160
Intercooler
Turbo to Intercooler Hose 17659-88381
Intercooler to Throttle Body Connector 17861-88382
Coolant Level Sensor 89256-22010
ST185 Turbo
Turbo Gasket Kit 04175-74030
Exhaust Manifold Gaskets (90-92) 17173-88381 & (93+) 17173-88382
Radiator
New Radiator 23300-74560
Radiator Fan Switch 89428-33010 ($78.95)
Radiator Relay 85925-17010 ($34.52)
Engine
Distributor O-ring 90099-14090
Distributor cap O-ring 19127-74040
Idle Speed Controller Gasket 22215-74380 ($3)
Idle Speed Controller Valve 22270-74080 ($148.50)
ISC Screws 21821-25180 ($.89 x 4)
Misc
Hatch Bump Stops 90541-09047 ($2.26ea)
ST185RC/CS Parts CLICK HERE
ST205 Intercooler
Standard ST205 17940-74080
WRC (GroupA) Version 17940-74100
Cross Reference
Those parts which can be swapped between models.
Toyota Suspension Parts (ST165/ST185 Swap)
REAR DIFFERENTIAL 41110-20330
WITH TORSEN LIMITED SLIP 41110-20370
REAR DIFFERENTIAL CUSHION 52291-20010
REAR KNUCKLE 42305-20290
REAR BEARING 90369-38003
REAR SEAL (INNER) 90311-56007
REAR SEAL (OUTER) 90311-52005
REAR CV BOOT KITS 04437-20020
REAR AXLES (NO ABS) 42340-20012(REQ NEW NUT & CAP)
REAR AXLES (WITH ABS) 42340-20022(REQ NEW NUT & CAP)
REAR STRUT ROD 48780-20030
DRIVE SHAFT CARRIER BEARING 37230-20121
DRIVE SHAFT 37100-20281
REAR SWAY BAR LINK 48830-20010
TRD Suspension Parts
REAR KNUCKLE BUSHING 48715-SW251
REAR STRUT ROD BUSHING 48715-SW251
Catalytic Converter Parts
Exhaust Gasket Lower (O ring) 90917-06056
Exhaust Gasket Upper (O ring) 25576-74030
Stud (Catalytic Lower x 3) 90116-10146
Nut (Catalytic Lower x 3) 90179-10070
Bolt (Catalytic Upper x 3) 90119-08374
Stud (Catalytic Upper x 2) 90116-08171
Nut (Catalytic Upper x 2) 90179-08072
