RX7 AFM
There seems to be some mystery surrounding the RX7 AFM.* This AFM has been used as a cheap replacement for the stock 3SGTE AFM (US market).* We will cover here the differences, and lay to rest (hopefully) any mystery regarding this AFM.
SPECS:
87-88 MAZDA RX7 (NON TURBO) Mass Air Sensor
NipponDenso Part #17100-3250
PERFORMANCE:
This AFM is roughly close to the stock AFM.* While some have claimed a better feel, no performance figures have been produced.
GAINS:
No gains have been reported, other than "it feels nice".* In an otherwise stock car, top end would be improved slightly.*
INSTALLATION:
The AFM is virtually identical to the original on the outside.* Your stock air box or aftermarket intake should bolt on.
TUNING:
The response may be different on the RX7 afm.* We will show later how to adjust this.
TESTS:
Here are the spec outputs from the MAZDA AFM vs the TOYOTA AFM.* You can see that they are virtually identical.* We will report more as we find it.
RX7 3SGTE
Voltages:
VC - E2 4.5-5.5V 4-6V
VS - E2 (Flapper closed) 4V 4-5V
VS - E2 (Flapper full open) 0.02-0.5V
VS - E2 (Idling) 2.5-3.5V 2-4V
THA - E2 (at 68degress F) 2-3V 1-3V
Resistance:
VS - E2 (Flapper closed) 50-500 200-600
VS - E2 (Flapper full open) 50-500 20-1200
THA - E2 (at 68 degrees F) 2,000-3,000 2,000-3,000
