    Default USDM ST185 Specs
    ST165 to ST185 Evolution
    Compression Increase to 8.8
    Transmission Oil Cooler Added
    Changed to Air/Air Intercooler
    Side Feed instead of top feed fuel rail (Same as MR2)
    Intake manifold slightly changed (Same as MR2)
    CT26 6 bolt elbow vs. ST165 CT26 4 bolt turbo elbow (Same as MR2)
    Twin Entry Turbo Upgrade (Same as MR2)
    Flywheel bolt larger diameter (Same as MR2)
    15" wheel standard
    CD Player option
    10 Speaker stereo option
    US Specifications :
    Engine:
    Code: 3S-GTE
    Type: Inline 4, aluminum head
    ValveTrain: DOHC, 16 Valve (4 Per Cylinder)
    Displacement: 1998cc (2.0 Liter)
    Bore/Stroke: 86mmX86mm
    Compression: 8.8:1
    Output HP: 200@6000 Rpm
    Output Torque: 200 lb/ft@3200 Rpm
    Redline: 7300 Rpm
    Dimensions:
    Curb Weight:* 1420kg (3320 lb)
    Weight Distrobution F/R:*50/50
    Wheelbase: 2525mm (99.4 in)
    Track F/R: 1480mm
    Length: 4420mm
    Width:* 1745mm (68.7 in)
    Height:* 1305mm (50.4 in)
    Ground Clearance: 160mm (5.1 in)
    Interior Room:
    Length : 1705mm
    Width: 1410mm
    Height: 1080mm
    Suspension:
    Front: MacPherson Struts, Anti Roll Bar
    Rear:
    Performance:
    0-60 Mph: 7.24
    0-100 Mph:
    Lateral G: 0.819
    60-0 Mph Brake:
    1/4 Mile: 15.3
    Top Speed:
    70Mph-0 Brake:
    Drag Coefficient: .34
    Fluids:
    Fuel Capacity: 18 gal
    Oil Capacity:* 4.1 qt
    Water Capacity:** 6.1 qt
    EPA Miles Per Gallon: 17.8
    Features:
    Standard: All Wheel Drive
    ***************** Alloy Wheels
    ************ **** Rear Spoiler
    ************ **** Fog Lights
    ************* *** Power Windows/Locks
    ************* *** Leather Shift Knob
    ************** ** Anti-Lock Brakes
    Optional: Power Adjustable Driver Seat
    ************* Leather Seats
    ********* ****** Double Adjustable Sunroof
    *********** **** 10 Speaker Live Sound System
    DriveTrain:
    Code: E150F/E151F
    Type: Transverse Front Engine, Full Time All Wheel Drive
    ********* Viscous Coupling Limited Slip Center Differential)
    Transmission: 5 speed manual
    Gear Ratios:
    *************** 1: 3.38:1 / 3.58:1
    *************** 2: 1.91:1 / 2.05:1
    *************** 3: 1.33:1 / 1.33:1
    *************** 4: 0.97:1 / 0.97:1
    ************* 5: 0.73:1 / 0.73:1
    ********* Final:* 4.29:1 / 3.93:1
    Max Speed : 137.5
    Steering:
    Type: rack-and-pinion, power-assisted
    Turns lock to lock:
    Turning Circle: in:
    Brakes:
    Front:
    278mm vented, 25mm thick
    Rear:
    288mm solid, 10mm thick
    Tires:
    Wheel Size: 15x7 in
    Tire Size: 215/50/15
    Lug Spacing: 5 lug x 100mm
    Turbo:
    Model: Toyota CT26
    Type: Water and Oil Cooled, Internal Wastegate
    Max Pressure:
    Intercooler: Toyota Air/Air Top Mount with ram air scoop
    Pressure Drop: ~2 psi
    Interior:
    Volume:
    *** Front:
    *** Rear: *
    **** Trunk:*
    Colors:
    040: White
    3E5: Super Red
    202: Black
    182: Grey Metallic
    181: Silver Metallic (1991)
    8G7: Medium Blue Pearl (90-91)
    3H4: Burgundy Red Pearl (90-91)
    749: Teal Metallic (92-93)
    92 All Trac-Daily Driver
    Is there specs for the 185 in a 165 body? Or do I need to go down to the track while my swap is still stock and let you guys know?
    Quote Originally Posted by ericfragola View Post
    You get some numbers, we'll throw them up here!
