US Specifications (1988):
Engine:
Code: 3S-GTE
Type: Inline 4, aluminum head
ValveTrain: DOHC, 16 Valve (4 Per Cylinder)
Displacement: 1998cc (2.0 Liter)
Bore/Stroke: 86mmX86mm
Compression: 8.5:1
Output HP: 190@6000 Rpm
Output Torque: 190 lb/ft@3200 Rpm
Redline: 7200 Rpm
Dimensions:
Curb Weight: 3270 lb (with options)
Weight Distrobution F/R: 59/41
Wheelbase: 99.4 in
Track F/R: 57.9 in / 56.9 in
Length: 171.9 in
Width: 67.3 in
Height: 49.8 in
Ground Clearance: 5.1 in
Suspension:
Front: MacPherson Struts, Anti Roll Bar
Rear: Struts with lateral links and 1 trailing link,
********* Anti Roll Bar
Performance:
0-60 Mph: 7.7 sec (7.3 in tests)
0-100 Mph: 22.4 Sec
Lateral G: .82
60-0 Mph Brake: 146 feet
1/4 Mile: 15.6 Sec @ 88 Mph
Top Speed: 135 Mph
70Mph-0 Brake: 202ft
Fluids:
Fuel Capacity: 15.9 Gal
Oil Capacity: 4.2 Qt
Water Capacity: 6.8 Qt
EPA Miles Per Gallon: 20 City, 25 Highway
Features:
Standard: All Wheel Drive
*************** Alloy Wheels
*************** Rear Spoiler
*************** Fog Lights
*************** Power Windows/Locks
*************** Leather Shift Knob
*************** 6 Speaker AM/FM Cassette Sound System
Optional: Anti-Lock Brakes
************** Power Adjustable Driver Seat
************** Cruise Control
************** Leather Seats
************** Double Adjustable Sunroof
DriveTrain:
Code: E50F
Type: Transverse Front Engine, Full Time All Wheel Drive
********* Viscous Coupling Limited Slip Center Differential)
Transmission: 5 speed manual
Gear Ratios:
*************** 1:* 3.58:1
*************** 2: 2.05:1
*************** 3: 1.33:1
*************** 4: 0.97:1
*************** 5: 0.73:1
********* Final:* 4.29:1
Speed Test***** Mph/1000Rpm********* Max Speed (mph)
*************** 1:************ 4.4********************** 32* (7300rpm)
*************** 2: ********** 7.7********************** 56***** ""
*************** 3: ********* 11.9********************** 87**** ""
*************** 4: ********* 16.3********************* 119**** ""
*************** 5: ********** 21.6********************* 140* (6500rpm)
Steering:
Type: rack-and-pinion, power-assisted
Turns lock to lock: 2.9
Turning Circle: in: 35.4 ft
Brakes:
Front: 10.0 in x 1.0 in vented discs
Rear: 10.6 in x 0.4 in solid discs
Tires:
Wheel Size: 14x6 in
Tire Size: 205/60-14
Lug Spacing: 5 lug x 100mm
Turbo:
Model: Toyota CT26
Type: Water and Oil Cooled, Internal Wastegate
Max Pressure: 10.2 psi
Intercooler: Toyota Water/Air Top Mount
Pressure Drop: ~2 psi
Interior:
Volume:
*** Front: 51 cu ft
*** Rear: 28 cu ft
**** Trunk: 16 cu ft
Type: Cloth or Leather Option, bucket seat
Colors:
040: White
3E5: Super Red
202: Black
182: Grey Metallic
752: Dark Blue Metallic
ST165 to ST185 Evolution
Compression Increase to 8.8
Transmission Cooler Added
Changed to Air/Air Intercooler
Side Feed instead of top feed fuel rail (Same as MR2)
Intake manifold slighty changed (Same as MR2)
CT26 6 bolt turbo downpipe vs ST165 CT26 4 bolt turbo downpipe (Same as MR2)
Switch to Twin Entry Turbo System
New Flywheel (Same as MR2)
15" wheels standard
Pictures Courtesy Shannon Rafferty
Information Courtesy Car and Driver
Special thanks to Arvin Dharmawi
