This is from AT.net. I didn't research or come up with it. Merely posting it here.
Celica All Trac GT- Four Engine & Performance Comparison Page
ST165
Engine Code 3sgte
Injector Size 440cc/m
Trans Code E50F
Turbo Code CT26
Turbo Type 4 Bolt Single
Intercooler Top Water/Air
Aero Design Front Vent
Bore 86mm
Stroke 86mm
Compression 8.5:1
Weight 1350 Kg
Output HP 185@6000
Output Torq 24.5/4000
Stock Boost 6.5psi
Max Boost 12psi
Top Speed 220km/h
1/4 Mile 15.6sec
0-100km 8.1sec
ST185
Engine Code 3sgte
Trans Code E150F/E151F
Turbo Code CT26
Turbo Type 6 Bolt Twin Entry
Intercooler Top Air/Air
Aero Design Hood Scoop
Bore 86mm
Stroke 86mm
Compression 8.8:1
Weight 1400kg
Output HP 225@6000 (USDM 200 HP)
Output Torq 31.0/3200
Stock Boost
Max Boost
Top Speed
1/4 Mile 15.2sec
0-100km
ST185 RC
Engine Code 3sgte
Trans Code E151F
Turbo Code CT26 Ceramic
Aero Design Hood Vent
Bore 86mm
Stroke 86mm
Compression 8.8:1
Weight 1460kg
Output HP 235@6000
Output Torq 31.0/4000
Stock Boost
Max Boost
Top Speed
1/4 Mile
0-100km
ST205
Engine Code 3sgte
Injector Size 540cc/m
Trans Code E154F
Turbo Code CT12A
Turbo Type
Aero Design Hood/Timing Vent
Bore 86mm
Stroke 86mm
Compression 8.5:1
Weight 1390kg
Output HP 242@6000
Output Torq
Stock Boost 10.8psi
Max Boost
Top Speed
1/4 Mile
0-100km 6.5sec
ST205 WRC
Engine Code 3sgte
Trans Code
Turbo Code CT20B
Turbo Type
Aero Design +High WRC Wing
Bore 86mm
Stroke 86mm
Compression 8.5:1
Weight 1380kg
Output HP 255@6500
Stock Boost
Max Boost
Top Speed 245km/h
1/4 Mile 13.8sec
0-100km 5.45sec
