Page 9 of 9 FirstFirst ... 7 8 9
Results 201 to 224 of 224
  1. #201
    I still think you've got two different headlight bulbs in there... ones more yellow than the other one.
  2. #202
    I'm sure that's possible, the left headlight assembly is from a donor car. However, I don't see what you're talking about with the "yellow"ness
  3. #203
    Drivers side is more yellow, passenger side is more blue/white.
  4. #204
    I am so happy this isn't in my driveway anymore.
  5. #205
    Me too. It drove really well, didn't pull or anything, but still getting alignment before driving it more, of course.
  6. #206
    Good man.
  7. #207
    Took the car down to Joey's. We took this stuff off:
    Did fronts too, but didn't take many pictures. We pressed out (our friend Gabe actually hammered out a few that didn't fit on the press right) the old worn out bushings and replaced with poly and did H&R springs and new Tokiko shocks that work with TEMS. If it wasn't a street car I'd probably remove TEMS and go with different shocks, but I still like being able to soften them up with a button push for bumpy roads. Couple pics of the new stuff.
    Made a huge and immediate difference. The old bushings were so bad the car couldn't be aligned in the rear.
  8. #208
    How does she feel? I mean, ride ok? Not too harsh?
  9. #209
    It's good, yeah. The springs are definitely stiffer, but (you'll laugh) the TEMS is handy for softening the shocks when I get on rough roads. I'm putting the new end links on today. Their length is adjustable, any reason I wouldn't make them the same length as stock?
  10. #210
    So, when the rear suspension was coming off for the bushings, the old crappy sway bar end links did not choose to cooperate. Joey cut one of them off, but the other side one nut did come off and allow the work to be done. Had to run with only one side hooked up for a week. Ordered aftermarket end links to replace them and installed them today. The stock end link that was still on there was in lousy condition. One nut came off, but the other end... lots of pre-soaking with lube and very careful work only got the other nut to the end of the bolt before it stripped. I ended up having to cut it off too. So glad I had a cut off wheel!
    Here are the new links installed
  11. #211
    You know, a couple bucks of spraypaint would have made all that work look worthwhile.
    Be she feels better though.
    Well, I've been failing at pictures, but recently I put in a new air intake temp sensor (had a bung welded onto the intake pipe before the throttle body) because the stock location heat soaks horribly and becomes almost worthless. After that went for more tuning and... the fuel pump was dying and dropping pressure on the high end. SO.. out with the dying walbro 255 and in with a 400lph pump instead. Back to the dyno today and it put down 470 to the wheels. For comparison, on the same dyno my tuner recently had some lightly modded vipers come in and make similar numbers. On a higher reading dyno it's probably in the 550 range. More importantly though, it now pulls smoothly all the way to redline and idles well and has PLENTY of power for the street. I need to get the sheets scanned in, but I'll probably fail and forget to do that Monday..
  13. #213
    Wow, just read this entire thread for the first time, what an odyssey!
    Lots of good work and sweet DIY eithic, would love to see this car some time.
  14. #214
    Damn! How do you think it'll fair at autocross next weekend? Would love to see those graphs!
    Sent from my HTC One using Tapatalk 4 Beta
  15. #215
    Hahah, it's going to be a horrible autocross car, but probably funny enough to be worth it
  16. #216
    Can't wait to see your car in action!
    Project Ava
  17. #217
    is that 400LPH fuel pump pretty loud when it's operating? I'm thinking about getting it if my NA pump isn't able to hold its own when on the GTE swap. Do you also plan to run E85 eventually?
    -Alex {](O_o)[}
    1993.5 Toyota Supra. Project Ren. 2JZ-GTE VVT-i V160 swap completed! Time to clean her up!
  18. #218
    Quote Originally Posted by NgoFcukinWay View Post
    It's actually pretty quiet. The 255 was louder. I don't plan on E85. It's not especially convenient to get where I'm at and too much trouble and expense to convert. Maybe eventually.. but I doubt it
  19. #219
    Damnit...
  20. #220
    Damnit...
    Elaborate...
    Project stinky is now in my driveway. I'm now heading up this project.
    And... she be broken.
  22. #222
    That looks painful.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    Oh Holy Shit.
    '98 GS400
  24. #224
    I just find amazing the work and dedication needed to be put into such a project. I mean, you've updating this thread for 7 years. Your work is outstanding, I salute you! Congratulations!
