Closed Thread
Results 1 to 1 of 1
    Default CelicaTech 1/4 Mile Registry
    Something I'm going to work on...
    # 1/4 Mile MPH 1/8 Mile MPH 60' Owner Model Modifications Date Country
    1 10.950 131.22 6.950 103.52 2.544 Patrick ChinShue 1993 ST185 EVERYTHING Sept 27/02
    2 11.114 128.60 7.281 101.96 1.850 Andy Ashby ST205 TTE crank/rods / forged pistons / GT28 / WI / 850cc inj / HKS valve spr. / ported head / Motec EMS Aug 7/04
    3 11.393 123.59 7.418 98.11 1.703 Jim
    Barbaris
    ST205 -
    4 11.838 121.92 7.749 96.23 1.817 Tony Charles ST205 TTE crank/rods / JE pistons / GT30 / FMIC / 1000cc inj / HKS valve spr. / ported head 272 cams / WI / Motec EMS / Tw.pl.clutch May 30/04
    5 12.23 117.07 - - 1.9 Johan Ohlen 1988
    ST165
    Plenty Sept 4/04
    6 12.408 111.99 8.011 91.08 1.837 Bill Price 1993
    ST185
    Garett GT25-400 / 750cc inj / HKS twin plate clutch / AFPR / Autronic / 264 cams / 3" exh / walbro 255 FP Apr
    28/04
    7 12.553 108.23 8.035 - 1.751 Alex Knight ST205WRC Built eng / Dastek Unichip / CM fx400 cl / FW / I/E / Adj FPR / Walbro pump / 1.6bar / 342bhp/332ft-lbs Oct 26/04
    8 12.581 110.24 8.098 88.24 1.760 Chris
    O'Rourke
    1990
    ST185
    JUN
    internals / 720cc inj. / T04E-50/T3 hybrid turbo / FMIC / Autronic / 272
    cams ++
    June
    20/03
    9 12.809 108.69 8.315 85.81 1.956 Nic ST185 To4e turbo / 205 head / built eng / 272 cams / 205 g/b / Motec EMS / 850cc inj Sept
    26/04
    10 12.906 (Video) 106.18 - - 1.736 Les Konczyk 1992 ST185 ST205 swap / exhaust / 20psi / WI / launch control April
    3/04
    11 12.938 107.91 - - 2.019 Toomas Saar ST185 JDM eng / Schwitzer S2BG 19psi / FMIC / tubular exh manif / I/E / BOV / S.S. June
    20/03
    12 13.002 107.260 8.397 85.410 2.060 Simon Dawes ST185RC I/E
    / WI / Stage 2 CT26 / Fuel and Ign / Clutch / FW
    13 13.101 101.892 8.308 82.102 1.746 Malcolm Graham ST185 I/E
    / FMIC / 50 trim t04e ct26 / 16psi / AFM mounted post IC
    Mar 12/04
    14 13.4 103.46 8.684 81.83 2.049 Steve Gilles 1988
    ST165
    44mm comp CT26 1.1bar / I/E / WI / FW / 165grpA IC / 205trans Oct 11/04
    15 13.445 100.68 8.615 - 1.923 Dan Johnson 1994 ST205 1.2 bar / Helix 4puck clutch / ORC 4.4kg FW / I/E / TRD coilovers / 337bhp / 287ft-lbs Sept 26/04
    16 13.512 106.14 8.884 85.55 2.315 John
    Stokes
    1990
    ST184
    JDM
    3S-GTE swap / Intake / Full Exhaust / 17psi
    April
    18/03
    17 13.564 100.81 8.662 81.27 1.802 John
    Willcott
    1996
    ST205
    WI
    / 17PSI / SAFC / Induction Kit / DP / Lowering Springs
    April
    6/03
    18 13.627 98.79 8.671 79.14 - Chris Dittrick 1988
    ST165
    JDM 185 eng/ecu / I/E / CT20b 14psi / FPR at 45psi / Walbro FP / RC wta IC / NGK plugs / FW/MHG/WI/BPV Sept 20/04
    19 13.644 101.040 8.698 81.310 1.792 Tony Charles ST185
    20 13.692 100.76 8.757 80.47 1.920 Conny Ruuth 1990 ST185 FMIC / Air Filter / 2.5" Exhaust / 15psi Sept 4/04
    21 13.717 100.03 8.810 81.55 2.053 Robert Hughes ST185RC 54 trim hybrid / 3" exh / DV26 bov / intake / 1.1 bar Feb 29/04
    22 13.796 95.648 8.717 78.622 1.837 Tim Wilson 1992
    ST185RC
    Air
    Filter / 2.5" Mandrel Exhaust / Fulltime fuel pump / 0.9-1.1bar
    Oct
    18/03
      14.324 94.865 9.278 77.199 2.064 Bex
    Wilson
    1992
    ST185RC
    Air
    Oct
    18/03
    23 13.799 97.05 8.792 79.47 1.973 Darren Warren 1991
    ST185
    JDM car / 1.1 bar / intake / exhaust May
    20/04
    24 13.829 97.940 8.823 78.420 1.872 Mohammed
    Zahir
    ST205
    25 13.90 99.26 8.96 78.56 1.928 Bryan Wilson ST185
    26 13.913 96.18 - - 1.852 Kevin Hall 1992
    ST185
    3"
    Exhaust / 50-trim CT26 at 14psi / Intake
    Sept 21/02
    27 13.962 99.556 8.969 79.243 1.959 Tim
    Wilson
    ST185
    Narrow Body
    Boost
    @ 1 bar / 2.5" Exhaust / Greddy DP / Intake / Fuel Pump full time /
    RC wta IC
    July
    27/03
    28 13.989 97.17 9.009 77.48 1.905 Jake
    Featherstone
    1990
    ST185
    3"
    Exhaust / 46 trim CT26 / 14psi / CAI
    Aug
    8/03
    29 14.001 97.490 8.921 77.710 2.050 Nigel Hayes ST185
    30 14.021 102.06 9.231 81.55 2.426 Mina Haroun 1994 ST Gen 3 3sgte / FMIC / SDS EMS / 11 psi Aug 22/04
    31 14.127 96.96 9.031 75.63 2.016 Karl Turner 1990
    ST185
    jdm car / 1 bar / 100 ron / full exh / intake / bov / mhg Sept 26/04
    32 14.242 93.43 9.012 76.23 1.934 Shawn
    Smith
    ST165 46
    trim CT26 / 14psi / F-CON / AFC / K&N Cone Filter
    Nov 14/03
    33 14.259 99.270 9.302 78.180 2.088 Karen Hancox ST185
    34 14.259 99.27 9.302 78.180 2.088 Nic Street 1992
    ST185
    Oct 6/02
    35 14.299 94.589 9.206 - 2.237 Steve
    Zaebst
    1994
    ST
    3S-GTE
    engine / 3" full exhaust / FMIC / 16" drag radials / solid
    rear motor mounts / coilovers
    Aug
    2/03
    36 14.342 96.520 9.294 75.550 2.204 Morgan Johanssen ST185 -
    37 14.382 94.36 9.273 75.48 2.085 James Unger 1988
    ST165
    JDM 185 eng / Streetbrawler T3T4 / 11psi / 264 cams / ST205 WTA IC Sept 11/04
    38 14.438 102.551 9.597 79.859 2.431 Julian "Jools" Lewis ST182 3S-GTE
    Swap / I/E / 3 pc. Org. Clutch / 14psi / LSD
    Nov
    29/02
    39 14.446 91.86 9.204 74.28 2.034 Steve Foster-Jones 1992
    ST185
     K&N
    filter / cat bypass pipe / 3" exh. / Unichip 14psi / BOV
    April 7/02
    40 14.459 97.660 9.311 72.140 2.032 Kenny Lam ST205
    41 14.49 91.65 - - 1.95 Tarik Fawal ST185
    42 14.495 95.030 9.392 75.770 2.165 Claire Rourke ST205
    43 14.520 92.510 9.319 75.640 2.214 Paul Wigzell ST205
    44 14.541 92.230 9.292 74.310 2.033 Simon Bower ST205
    45 14.668 91.86 9.312 73.69 1.909 Josh Winegar ST185 Gutted exh / muffler / BOV / Intake / EBC at 12psi March 15/04
    46 14.755 89.56 9.329 72.58 1.887 Scott
    Livingstone
    1987
    ST165
    10
    psi / K&N Panel Filter / 2.5" Exhaust
    Nov
    15/02
    47 15.081 90.52 9.695 72.86 2.260 Paul Smith 1990 ST185 3" Aussie DP/MP / JDM ECU / 10psi / ST205 gearbox
    Mar
    12/03
    48 15.241 91.701 9.887 73.436 2.378 Darth Beater 1985 GTS RA65 Built engine / turbo / standalone ems -
    49 15.291 90.59 9.827 71.99 2.216 Chao Xiong 1988
    ST165
    Sept 9/02
    50 15.327 90.140 9.831 72.080 2.197 Davy Patterson ST185
    51 15.575 87.10 9.939 70.00 2.198 Jason
    Bemont
    1992
    ST185
    TWM
    Shifter/bov/gutted cat/CM stg.3 clutch / LW FW / 3ang. valve job / bcc /
    mhg / 10psi
    July
    16/03
    52 15.5803 85.81 9.8657 69.11 2.0959 Justin Perrin 1993
    ST185
    18" Wheels Sept
    12/04
    53 15.639 87.01 10.004 69.65 2.229 Dan
    Choo
    1991
    ST185
    Boost
    to 0.8bar / Gutted Primary cat
    July
    27/02
    54 15.69 85.71 9.9733 68.87 2.1575 Justin Perrin 1988
    ST165
    Cone
    filter / CT26 to4e 50 trim / gutted cat / spec stg 2 clutch / stock
    boost
    Nov
    9/03
    55 15.70 84.00 - - 2.10 Melissa Trinka ST185 3"
    DP/BOV/HKS Intake
    56 15.71 85.99 - - - Brian Melket ST185
    57 16.240 83.380 10.357 65.320 2.241 Ian Stewart ST185
    58 16.694 81.37 10.692 - 2.483 Troy
    Howatt
    1992
    ST184 GT
    Cone
    Air Filter / Muffler / TWM Short Shifter
    June
    8/ 03
    59 16.781 81.640 10.754 64.510 2.592 Martin Ball ST182 Factory -
    60 16.943 81.66 10.957 65.53 2.648 Nate ST184 Header
    / Exhaust / K&N filter
    April
    27/03
     ...to the topTop
  1. 7th Generation Celica 00-05 Maintenance Guide
    By DrPaine in forum 7th Generation
    Last Post: 08-01-2005, 08:33 AM
