Results 1 to 9 of 9
    Default where does this go
    just got the alltrac back from fixing the shifter cable.i go to put the lower dash and center console back together. when done i had no radio no dome light no door lights no clock and no low beam on the drivers side,will do high beam.i have searched and checked all the fuses and even replaced them the only other thing i found was that the battery neg. terminal had the one ground to the frame BUT the other wire was just hanging.was wondering if this missing ground would be the prb ,and where to ground it to i think its the engine or tranny but i dint take it off so i am not sure.the reason i think it is the ground is everything was working (electric wise) before the shop fixed shifter.i have looked at the bgb and thru pages of search and couldn't find what i needed thanks in advance for everyone's help.
    got a picture of the mystery wire? What color is it?
    I play well with others....
    Others, Not you.
    no picture sorry its just a black cable apx 3ft long coming from the batt.
    any idea of the gauge of wire? Thick, thin? Sounds like a ground wire to me. What year is the alltrac?
    Others, Not you.
    i don't know gauges,but i do know its a ground as it comes from the negative batt. terminal. just don't know where it goes to.as far as the size about the diameter of a cigarette.the car is a 1990
    Sounds like your engine ground, you say you have the body ground and its "ok".
    There should be a bolt within range of that wire on the engine. It may be tucked away somewhere. If they loosened it (don't know why they would for a shifter cable repair) then you may notice its shinier then the others (from the socket). But I'm almost positive thats what that cable is. (pictures really help)
    Others, Not you.
    If you can't find the original spot it was wired to, don't worry about it.
    You can connect the other end to any non-painted, clean surface on the automobile chassis.
    Tom
    Windsor Ontario, Canada
    1990 ST185
    1990 Corolla SR5
    "The best way to predict the future is to invent it"
    ______________________________
    well i was moving everything around to see if it was a wire it turned out to be the plug on the underside of the fuse under the hood wasn't plugged in all the way. thank you for all the help guys
    No problem, glad you figured it all out.
    Others, Not you.
