Results 1 to 25 of 46
    Jul 2006
    monroeville alabama
    Default Finally an alltrac dyno
    311 hp
    285 ft lbs
    20 psi
    engine:
    ross 8.5:1 pistons .20 over
    eagle rods
    gsc 268 cams
    engle valve springs
    8000 rpm limit
    cometic hg with arp studs
    block and deck shaved flat
    rmr intake manifold
    q45 tb
    koracing gt3076r turbo kit .63 a/r exhaust housing
    3" exhaust
    open dump
    blitz dsbc
    hydra nemesis 2.5
    speed source rail and regulator
    supra tt fuel pump
    880cc injectors
    30x12x3 fmic with 3" piping
    Weaksauce
    It is weaksauce.
    Tune yo shit bugs!
    Hey baby, you want some fries with that shake? Waffles! is a name known to all Waffles! is a name known to all Waffles! is a name known to all Waffles! is a name known to all Waffles! is a name known to all Waffles! is a name known to all Waffles!'s Avatar
    Waffles! has been to an annual Dragon Meet! Waffles! has donated to the forums! Waffles! helped get Grayscale's Celica towed from The Dragon in 2008. Waffles! helped Azzy get to The Dragon in 2009. Waffles! helped bring Chaos back to the Dragon Waffles! helped KM replace his 5-year-old clutch.
    Apr 2008
    Georgia
    Shit boy! Tune the car!
    Originally Posted by temperacerguy
    OK, the german sheppard is hot
    real girls give stick
    /yourself
    Jul 2006
    monroeville alabama
    it is pretty weak for what i have done. i can tell it needs more timing in boost.
    Can't you alter that with the Hydra unit?
    Seems to me you should be able to pull about 50hp more at the boost level you're running on that turbo Bugs.
    Aug 2005
    Toledo OH
    tune your shit ! sounded good though, but have to agree you should be at around the 360hp range I would think.
    you got pm too
    Quote Originally Posted by donteatbugs View Post
    Yep, for sure. Torque dropping pretty significantly once the RPM's get up there (where the 3076 should be best, especially on an engine that will flow well...). What does the timing map look like? Also, did you degree your cams w/ a degree wheel?
    But yeah, you should be able to prevent the torque from dropping like a stone like that. I'd bet either cam degreeing or more ign advance required.
    Thats exactly what weve concluded Chris. Needs to tune the cams and the ignition table better. I drove the car today tho. Holy shit that thing moves.
    Senior Member v8killer is on a distinguished road
    Feb 2007
    Hollister, California !!!!!
    call this your baseline lol
    black st165 sleeper- the v8 killin' 2.0L bottle of whoop-ass!
    mods: you wish you knew!
    "Straight lines are for fast cars, turns are for fast drivers" Colin McRae- RIP
    Originally Posted by Luni
    Are you serious?
    Jesus, you really should just get a fucking sportscar that was designed to go fast.
    These are definately not the responses I would expect people to be saying about a dyno over 300 lol.
    Quote Originally Posted by 3tcpower View Post
    We're not knocking him for having 300+, we're simply informing him that his mods should put him above the numbers he put down.
    With that turbo and the boost level alone he should be well above the 300 level.
    Jul 2006
    monroeville alabama
    i was just wondering what i was making, this give me a place to start with my ignition tuning. i think im almost at the limit of only street tuning. i think the rest will need to be on a dyno. i love the way the car drives right now and its very conservative tune for safety.
    Do you have a J&S Ultra Safeguard unit yet Bugs?
    At the levels you're looking at, I would highly recommend one.
    Ill agree Bugs. The dyno numbers dont say alot, but holy fuck your car is fun to drive. Its fucking fast too. It definately ges up and moves.
    Did I mention its fun as fuck to drive? Cause it is.
    Bugs car is badass. It doesnt get the street cred it deserves. Id roll that fucker anyday in a heartbeat.
    Too bad he wouldnt let me drive it with ALL the boosta. I only got 14 psi.
    Definitely looks like you've got a solid base to work from. I'd agree on the street tuning. It is pretty tricky, especially the timing side of things. Especially, especially, when you see an experienced tuner do in a matter of minutes what takes you hours.
    Did you degree those cams tho? That's one thing you can do without a dyno...but you'll need to readjust the fuel for sure after. I got my degree kit for $100 at summit.
    3076 is one of the turbos on my "short" list...very interested in your progress bugs!
    Shingle Springs, CA
    Which means that he did a great job on tuning cruise to boost transition. Congrats Bugs, now its time to utilize the full potential of your setup!
    Jul 2006
    monroeville alabama
    tune is decent seeing as i get 17 mpg in boost/around town and 24 on the highway.
    i was getting an average of 2.5v at the knock sensor and a peak of 3.6v. i dont know exactly what to aim for but my threshold when i got it from rickyb was set at 4 basicly
    Sep 2007
    MD
    my threshold is much higher than that bugs. the damn hydra is very touchy on the knock sensor.
    very nice dyno BTW. 310 at every wheel is great! yes it can be better (can't we all get more tuning time in!) but from what i see it looks great! pump gas too IIRC, right? what was the temperature outside?
    I will miss you, my friend.
    Jul 2006
    monroeville alabama
    temp was good, around 70 i think but it was raining outside. mafix if you dont mind emailing me a map and data log from your nemesis. something high boost and 3rd gear. id like to look at your knock and timing. my email is donteatben@gmail.com rickyb recommends zipping the files so it doesnt get corrupted in the transfer.
    Those numbers are nothing to sneeze at. What dyno did you end up going to?
    Jul 2006
    monroeville alabama
    batlground performance in atlanta
