Results 1 to 13 of 13
    Lifetime Member shreddr69 is on a distinguished road
    shreddr69 has donated to the forums!
    May 2010
    north California
    Default stripped axle allen bolt, need it out! HELP!!
    So we were pulling apart my 88 all trac for an engine swap and one of the driver side axle bolts (the big allen bolts) stripped. Not the threads but the head itself. Should we just jam a big torx head in there and use the impact socket to jack it out or is there a better way? I need a new bolt anyway, so I'm not worried about the bolt but I'd sure hate to mess up my axle in any way. The car's older and sat for the last 8 years so I suppose I should have expected this to some degree but it's never a happy thing. Thanks in advance for any help y'all can give. ROck on!!
    Any time I have a bolt that gets stuck like that I always turn to my bolt outs like these http://www.sears.com/shc/s/p_10153_12605_00952166000P
    They work every single time. It wouldnt hurt to soak the bolt down in PB blaster first though.
    You could also cut a slot in the bolt head and use a heavy duty screwdriver .... I think you get the idea.
    I play well with others....
    Others, Not you.
    Quote Originally Posted by RIalltrac View Post
    I have a set of these too, they are great! However, I am not sure they are big enough for this application? (if he's talking about the big f'er axle nut)
    Is that what you mean? The 29mm big f'er? Were you using a proper axle nut socket? It is extra deep so that you avoid stripping. I just removed one that required a solid 700ft-lbs to pull, and we didn't strip. But if you are talking about a different bolt and not that nut, then maybe I'd recommend something else.
    If you weren't using a deep socket, go get one from an auto-parts store, they will have it. Might be in a different spot than the regular sockets.
    I think he's talking about the allen head bolts that hold the inner part of the axle to the output shaft on the transmission.....
    I would agree though on the axle nut bit, those are definately far too small to tackle a job like that. Plus if you round off an axle retaining nut....your doing it wrong....
    May 2010
    north California
    Yeah it's the smaller allen head bolts. Thanks for the tips, We're goin' at it this evening so I'll post how it went tomorrow. Thanks again!
    Ahh, crappy. Good luck.
    You could slowly back it out with a set of vice grips or try. Be sure to order new ones before you do it tho so you can reassemble it when you get it out.
    And dont forget to locktite them when reassembling them.
    May 2010
    north California
    I'm not sure I can fit vice grips on it but I'll try. All these ideas are cool.
    May 2010
    north California
    vice grips didn't work, I've got those stripped bolt sockets from sears I'll try today but the bolt is round. If those don't work then it's the grabit extractor and if THAT doesn't work I'll dye grind a slit across and try to get a screw driver or a bar in there and twist it off and if that fails, I guess I'll cut the bolt head off and pound the axle until it falls off. If anyone knows where to get axles for these all tracs please let me know. This bolt is starting to mess up my week, LOL!
    how about welding a nut to the damaged bolt and removing with a socket??
    Why dont you just pull the flange out with it so you remove the entire axle assembly? You are going to lose a bit of gear oil but thats no big deal.
    Red st165
    White st165
    Black st165 (finally gone)
    May 2010
    north California
    That's what I'm trying to do but the inside of the alan bolt stripped and the only way I've found to get it off was to cut the little pest. We've tried welding something to it, it broke off, vice grips, that was a joke, a torch, no dice, then a cutting disk and that worked. So we're on our way. Thanks for all the help!
