Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 26 to 50 of 140
Thread: "Chaos Theory"
  1. #26
    Thoughts on the Coil-Overs:
    The only problem I had with the Megans was a minor one, the brake likes did not fit into the brackets, they will have to be filed out, not much, maybe a mm or two.
    I have only put about 20 miles on her since the install, I am planning a drive today. I currently have them turned down to 15 from full hard, and that is rather stiff, for street driving it might be absurd. I am gonna go do some testing this morning and turn them down to about ~20-22 to see how that works.
    Chaos is running 215/40/17 tires with a 40mm offset on a 7" rim. No front sway bar, no front strut brace, she is a coupe. She also received ball joints and new tie rod ends at the same time.
    Steering is much sharper, and very crisp. She feels very planted. She is currently ~1.75" lower than she started, and I am getting minor contact on hard bumps. This could be due to body damage on her fender and quarter, so I will be doing some massaging as well, until I source widebody fenders.
    More thoughts to follow.
    Pictures as promised!
    Low enough?
    Meaty!
    The inner fender liners are gonna have to come out.
    They shouldn't need to. Why do you want to pull them?
  5. #30
    Because he dropped it a ton.
  6. #31
    I know he did. Mine was dropped further and there was no need to remove them.
    So I am curious as to why he's gonna pull em.
    Did you remove yours Marshall? I cant remember anymore.
  7. #32
    The fenderliners are damaged, and they run, badly.
    Plus with the widebody fenders, they won't fit anymore.
    So did you get out to the yard and find a set of fenders then Murg?
    If so, or you are able in the future, I would pull the fender liners from the donor car.
    If you are not going to do that, spend $40 on pint of POR15 and give the entire underside a good coat.
    Those liners go a long way to preventing water and debris from getting into certain areas.
    If they are no longer there, you are inviting rust to come play.
  9. #34
    No, I don't have them yet. I haven't been to the yard, I have been playing on the Dragon.
    Man has to have his priorities you know.
    Did the wheel stud issue get taken care of yesterday at the shop?
  11. #36
    I guess. It wasn't seated all the way, but I can't get it to seat. The kid who did my alignment and tires was a special fellow. I don't think he liked Chaos. His vocabulary involved mostly four letter words and his face was stuck in a scowl.
    I did feel even better this morning when I went back because I had a leaky valve stem, he didn't tighten it all the way.
    My favorite part was when he told me he couldn't do the alignment because he couldn't get the tie rod ends to break, said I needed new ones before he could finish it.
    The tie rod ends had been on her for less than three hours.
    Sounds "special"....
    There my friend, lies the difference between a Tech and a Tire Monkey.
  13. #38
    Oct 2008
    Under There
    murg, i run to pap at least every 2 weeks. i will keep you poster as to what arrives.
    Originally Posted by BabyBear
    Ive decided youre gay.
    Good day.
  14. #39
    So I am having fun finding the sweet spot on the dampers.
    With just me in the car, at 10 clicks from hard, she doesn't contact on anything harder than a 180* switchback. However, that is enough to unseat you on a solid bump at highway speeds. At 20 clicks from hard she contacts on on/off ramps, but rides very comfortable.
    Right now, I am making plans to source the fenders, as I am not gonna play the 'how hard can I be comfortable without contact' game.
    Once the widebody fenders are on, I will get down to proper adjustments.
    The rears at 15 from hard feel just right.
    I also have some 1/4" spacers for the rear.
    Really think those megans look good on there. I may have to invest in a set for Jasmine...
  16. #41
    So my passenger side headlight motor gave out last night.
    Looks like I get to source a new one this weekend as well as some fenders. Then I need to install my rear spacers.
    what kind of spacers did you end up getting? size?
  18. #43
    1/4" spacers, they are just shims.
    Spacers and strut tower bar installed today. I also installed my radio bezel I have had in the trunk for a couple of years. I got tired of moving it around.
    does it look even now after the spacers?
    It brings the rears out a good chunk, making it look more even. They are now just a mm or two shy of contact with the fender lip, so that is about right.
    Did the headlamp get fixed as well?
  23. #48
    No.
    The only 5th gen on the yard had the motors taken already.
    I found a headlight for the Buick (and a hood and a fender and a door) and the strut tower brace for Chaos, but that was about it. The pickings were slim today. I only bought two pieces today.
    nice, i like, btw i think u need to start a build thread for the buick
