View Poll Results: What Brand of Tires do You Buy?
Voters
99. You may not vote on this poll
  • Firestone
    2 2.02%
  • Goodyear
    2 2.02%
  • BF Goodrich
    8 8.08%
  • Hankook
    7 7.07%
  • Michelin
    4 4.04%
  • Dunlop
    6 6.06%
  • Bridgestone
    4 4.04%
  • Pirelli
    4 4.04%
  • Toyo
    6 6.06%
  • Anything on sale
    8 8.08%
  • kumho
    19 19.19%
  • other
    29 29.29%
Page 4 of 4 FirstFirst ... 2 3 4
Results 76 to 89 of 89
  1. #76
    Martinez, CA
    i am thinking of using the s drives, but they are a little more than i wanted to spend. we shall see.
    ST165
  2. #77
    Quote Originally Posted by jaydog82 View Post
    You can usually get a good price at Discount Tire. They will match the competition. I have also gotten great service from them.
  3. #78
    Martinez, CA
    ya i found them in a 205/55r15 for $102 each, the nitto neo gens are $80 each in a 205/50r15.
    ST165
  4. #79
    I got my 205/50/R16s for $350 out the door mounted, balanced and installed.
  5. #80
    Martinez, CA
    nice, where at?
    ST165
  6. #81
    Actually in Salinas.
  7. #82
    I am currently running some BFGoodrich G-force Sport Comp2's in 205/50/r16. They are great on the street, and I have even ran them at a couple AutoX events and they have been awesome.
  8. #83
    Most of my tires come from the pick n pull or from one of my salvage yards.
    I probably shouldn't admit that.
  9. #84
    Earth
    My 1 series has conti premium contact v rated run flats. And my 3 series is running Bridgestone Potenzas runflats (not impressed with the wear so next summer they get conties) and I run Bridgestone blizzaks on both cars in the winter.
    Posted from Imperial walker 17a via planetary datcom server
    BM Dubyou
    No Automatics in this family!
  10. #85
    switched to Yokohama s drive, this summer n was very impressed
    R.I.P Cherry Bomb (1990 Celica ST)
    They call me Hadoken because im DOWN RIGHT FIERCE
  11. #86
    Martinez, CA
    decided on using bridgestone re11 205/50r15, they are a bad ass tire.
    ST165
  12. #87
    Ultimo Miembro Fantįstico Gigantesco Mafix is a glorious beacon of light Mafix is a glorious beacon of light Mafix is a glorious beacon of light Mafix is a glorious beacon of light Mafix is a glorious beacon of light Mafix's Avatar
    Sep 2007
    MD
    race on hoosiers. drive on nittos. although i might be dropping nitto in favor of a more all season tire.
    I will miss you, my friend.
  13. #88
    Dunlop, lately, although size availability has been a little bit irksome for the Z1 and Z2's. I wanted 225/45/16 in the Z2 for the MRS, but they aren't releasing them until June so I'm settling for 205/50/15. I've been pretty happy with the Star Specs on the supra though.
  14. #89
