View Poll Results: How many flat tires have you had in the past 12 months?
- Voters
- 90. You may not vote on this poll
none here surprisingly, especially considering all the job sites i drive around
God I hope my luck dont change, Ive driven 45K mi in the last 8mo.
CelicaTech Supporter
I am one lucky person the last tire problem I had was with my chevy p/u it passed me at 65 mph. That was four years ago.
Had 1 blowout last year with the wife driving.
Thanks God she was ok.
Then I got called to come change it out to our spare... :lolhittin
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Questions? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. .
Member
i had a few on the commute to and from work
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Originally Posted by DudeMan
I'm like the energizer bunny on crack
Parting out my celica-click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
well the one on the truck goes flat every 2 weeks but thats cause i havent pull the bad tires off it yet, which the previous owner plugged the sidewalls:smokin:
85 celica gt-s @311k...22RTE will 2016 be the year Joe fixes the 3rd gen To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
I haven't had a flat in 5 years. Of course...I only drive ~2K miles/year, most of it highway.
Member
I got a cracked wheel early this year, tire was fine but went flat on the junk wheel.....
I had a flat tire not long ago in the 2. I was following Marshall, but some how he didn't see me pull over.
zippo. i'm too keen on maintenance.
I will miss you, my friend.
Mine was courtesy of the paving contractor that the WV DOT was using to pave I-64. They had cut the pavement down right at an expansion joint on a bridge. It severely damaged the sidewall but didn't immediate go down. That happened on the way home from work.
Had one on the Jeep, and then I believe I had one in the Celica, can't remember.
Too many to count. For some reason my beads are no longer locking on the rims fully, so every couple of days I walk out to a flat tire or two.
One valve stem issue and one caused by corrosion of the AL wheel.
1988 ST165 2.2L @ 370awhp To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
(SOLD) 1994 ST205 WRC To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
I had one on my daily. I saw the damn truck bouncing nails & shit out of it, called the cops about shit not being secured. Shit bit me and I caught a dozen nails in a tire
Her Build thread --> To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
I have had one on the Buick. I replaced it, then got a nail in the new one and plugged it.
I replaced one tire for chunking. Again, on the Buick.
I have a slow leaker on Mudhoney. I haven't driven her in a year, and it is about halfway flat.
Chaos has two baldies, but no flats.
Millie has good tires.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Chaos `90 Celica
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Harmony `13 Mustang
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Originally Posted by Tallahassee
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Originally Posted by Vince
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Originally Posted by Murg's Wife
2 for me! Keep picking up screws in the rear tires. Must be from backing into parking spots all the time...
One. I flew through a parking lot in reverse and hit a curb in my GT.
Member
zippo for me.........ive changed rims like four times tho in the last year.
Member
~-=DEATH BY SNOOCH SNOOCH ! ! !=-~
: BEWARE OF CRAZY ROMANIANS :
TRACK STATS AS OF 3-14-10:
0-60; 6.45sec/ Quarter mile:14.7 @ 126.7mph, uti dyno run: 226bhp 200-/+Whp @ 6300rpm
From a*almost STOCK JDM 3sGE, with a USDM ECU first gen, COLD AIR,oversized injectors, and a cracked Cherrybomb for that growl (lol!)
Superstreet cover? -FAIL!!!!
Member
I have never had a flat in a car, I have had a bike tire randomly explode while it I was sitting on my couch though.
1990 Toyota Celica GT-S
I've only ever had one flat tire in 30+ years of a driving and well over 60 cars owned. That one was also a slow leak that only required a plug.
My mom and dad on the other hand have had 3 this year and they only drive about 3k miles a year between the both of them.
― Clyde DeSouza,
- You may not post replies
- You may not edit your posts
Forum Rules
