Results 1 to 1 of 1
    Default 3sge flywheel questions
    I'm doing a 3sge BEAMS swap. I would like to use a 3sge flywheel from a late 89 Celica GTS and a 3sgte pressure plate from a mr2. I'm also using a S54 tranny. Is there any problem with that? While searching for parts I've seen a slight differance in the flywheels for this generation of Celica GTS's. The early 89s and previous years use a flywheel with 115 teeth. The later 89s came with 120 teeth. Can somebody explain that?
