    Hyper
    Smile changing the power steering pump, how hard?
    Hey all,
    Has any1 changed the power steering pump on a 5th gen celica? My power steering pump is leaking , and I found another used one, better condition in a junkyard. Is it hard to change it? I went under the car to look, and it has a belt on it. I would have to remove the nut that holds the pulley first, correct?
    Please shed some light. Thanks ahead.
    hyper
    You'll have to remove the alternator belt. In order to do that, loose the alternator, and the belt will come off.
    There are two bolts that secure the power steering pump in place: the pivot bolt and the locking bolt. Don't forgot to remove the two hoses that are connected to the pump.
    Hyper
    Thanks, I'll give it a go this weekend.
    Jigglypuff
    Be warned though, it's a bit tricky trying to get any tools down there.
  1. no power steering
    By death in forum Maintenance, Troubleshooting, & Repair
    Last Post: 03-15-2005, 10:40 PM
  2. Fuel pump died.... HELP..!!!
    By Luis C in forum Maintenance, Troubleshooting, & Repair
    Last Post: 02-16-2005, 01:10 AM
  3. Power Steering Woes...
    By Sean in forum Maintenance, Troubleshooting, & Repair
    Last Post: 02-14-2005, 03:08 AM
  4. lack of power hard to start
    By hayeslogtruck in forum Maintenance, Troubleshooting, & Repair
    Last Post: 01-16-2005, 07:42 PM
  5. Power Steering Woes
    By LLB in forum Maintenance, Troubleshooting, & Repair
    Last Post: 01-04-2005, 02:23 AM
