Page 21 of 21 FirstFirst ... 11 19 20 21
Results 501 to 523 of 523
  1. #501
    Yeah I like it too. Tougher look.
    For the haters
    Sent from my Pixel using Tapatalk
  2. #502
    Just throws off a clean engine bay look.
  3. #503
    I think it adds to the clean engine look.
    I like the look of a well-done wrap, but I hate getting itchy every time I get near it.
  5. #505
    Good to see you're making progress and that's good to know regarding the cam sensor gap; I'm running the same setup. What are you running for cop setup and did you have to fab the spacer? Keep pushing!
    '00 SC300 - "The long way home" daily driver
    '88 ST165 - Project "Caun Beef"
    '91 MR2 - Project SCCA
    '93 Corrado SLC - "Purple Haze"
  6. #506
    The COP spacer is the one from RacerX. That part is ok, no problems. I had a lot of fiddling with the crank setup though. Had to get different bolts for the bracket and use washers to space it further, the wheel didn't fit nicely on the GT4 crank pulley, and also the 60T wheel comes extremely close to the chassis.
    But...it fired up yesterday...more to come.
  7. #507
    I really wanted to go with the late gen 5s crank trigger setup, but wasn't sure it would work with the moroso pan. So yeah, in the same boat as you with that too. Fired up? That's what up!
  8. #508
    I like the 5s setup too. I have a spare sensor and pulley /trigger wheel too, but didn't think of it until I was dealing with the racerx setup. My gut says it would probably work with the moroso pan and I could probably take a peek once the car is back. Right now it is at the shop getting prepped for tune.
    And heck ya!! I am really excited. It promptly spat a coolant leak out of a weld on the coolant neck (hard to weld that metal, also I had it coated so that was a bit of a headache for the welder). So I've pulled that off to be patched up. After that we'll get it up to temp, dump the oil, and go through the pre dyno inspection.
    For startup I'm using Joe Gibbs break-in oil. I'll use it for first start, then dump it, put in fresh, tune to wastegate pressure, dump it again and then put in Motul 300V for the higher power tune.
  9. #509
    So here's the latest. Coolant neck all welded up and that one solved. We got the cold start set up and it fired to life. Teaser vids in the next post. Use speakers or headphones to try to get a sense for the sound.
    Have to chase down a couple things, my rad fan wasn't turning on so I'll check that out tomorrow - either a bad relay or something with the wiring, as the relay does click to engage. Also, watching the fuel pressure data live showed it was quite unstable, especially at lower pressures. Decided to change the setup slightly as I don't think the Aeromotives are the best really. Mine also had a vac leak out of the top set screw which I hear is very common. Going to pull out the Aeromotive FPR, and install a Radium unit along with an inline fuel pressure damper. I'll get that in tomorrow as well.
    If all goes well, we'll be tuning next week.
  10. #510
  11. #511
    Idles awfully smooth for a big power car....
    '98 GS400
  12. #512
    Sounds great!
    Project Ava
  13. #513
    That's interesting about the aeromotive fpr. I've used them exclusively over the many years and have never had an issue with them, but have also never seen a real-time view of the fp data. Very curious how your changes will look in the real-time view. Car's sounding good!
    Btw.. More pics of the escort in the background please.. :-)
  14. #514
    lol, everyone wants to see that one. Funny cars those ones. I should be back tomorrow and will take some. Super rare and valuable these days though.
    Rad fan fixed, it was the relay, at least in current conditions the single SPAL had no troubles cooling the engine down. Got the first oil change done and fixed a leak off of my oil temp sensor setup. Also swapped in a spare alternator, but didn't solve my issue but it is almost 100% the wiring at the fuse box. Should have tested first, but I've had alternator issues in the past so I thought that might be an easy fix.
    Anyone done a custom fuse box? I think that may be a winter project. I'm dealing with mine and it's a bit messy. And now having a few extra relays like the rad fan, starter, with fuses, might be nice to get one integrated. Haltech has one but I don't know if it can also support a big alternator relay.
    Anyway, will go back tomorrow, deal with the alternator and try to get the new FPR and dampener mounted. A bit tricky without my own garage to work out of (making new lines possibly, brackets etc). Oh well last little things. Pushing to get it tuned before snow! And it is really threatening as we've had some already.
  15. #515
    Escort Cosworth pics
    I have no info on it but could ask next time.
  16. #516
    I realize that every pic in this lot could lead to more requests. Usually good stock of subarus here and a myriad of Jdm Imports.
  17. #517
    That escort and a ST205 are def. on my list of cars to own! What do those go for on your side of the border; I'm sure they still cost a penny! Thanks for the pics..
  18. #518
    Quote Originally Posted by GT4_Dred View Post
    Hm I'm not sure but I can ask a friend of mine who runs an importing company. Apparently it hit the dyno yesterday.
    https://www.instagram.com/p/BaWlVKyDR2e/
    https://www.instagram.com/p/BaVYtANnUOg/
  19. #519
    They are eligible for import to the US now, the `92s that is.
    Asked him and he said likely $50-70k CAD. The trouble would be to find one with how rare they are globally.
  21. #521
    Radium fuel setup now complete. Had to make a couple new lines and was reminded how pricey PTFE fittings are!
    Will likely move my fuel pressure sensor down to a port on the pressure damper to get it out of the way and clean it up a little bit yet.
    Next have to sort out why my alternator is not charging and will take the chance to clean up some wiring messes from things I did years ago that I'm not too happy with now.
  22. #522
    Got the Racepak wired in. Now to adjust the page displays, but really love this thing. Will be awesome to remove a bunch of gauges. Ordered a CF panel which I will mount it to in the stock location.
    Snow has fallen so dyno might be on hold for a while, we'll see. I'll just keep poking through my long list of things to do.
    Racepak video...
    https://photos.app.goo.gl/7WCI82JILZKNebOr2
  23. #523
    That looks pretty damn cool!!! Excited to see it in action!
    Project Ava
