Page 10 of 22 FirstFirst ... 8 9 10 11 12 20 ... LastLast
Results 226 to 250 of 526
  1. #226
    What's with the torque dip between 4-5k?
    It's gotten better, but it's still there.... Seems like it's where the tvis should open but you've pulled that right?
    '98 GS400
  2. #227
    Is that an AWD eddy current dyno? That power curve looks great!
  3. #228
    The Ultimate Celica Driver
    Proof of 14.7 required...
    vip09 has a brilliant future vip09 has a brilliant future vip09 has a brilliant future vip09 has a brilliant future vip09 has a brilliant future vip09 has a brilliant future vip09 has a brilliant future vip09 has a brilliant future vip09 has a brilliant future vip09 has a brilliant future vip09 has a brilliant future vip09's Avatar
    vip09 ran a 14.7 on the Dragon! vip09 has donated to the forums! vip09 helped get Grayscale's Celica towed from The Dragon in 2008. vip09 helped Azzy get to The Dragon in 2009. vip09 helped KM replace his 5-year-old clutch.
    Mobile, AL
    Cool stuff man, I ran out of fuel at the same boost pressure on a Td06 on stock fuel system back when I had the alltrac. The td06 was much more fun at 17psi, and A LOT of fun at 21psi. Congrats on having it running!
    Best GT-S STOCK times: 1/4: 14.788 @ 94.98mph 1/8: 9.640 @ 75.87mph
    Best Alltrac times: 1/4: 12.2 @ 115mph 1/8th: 7.9 @ 91mph
    Originally Posted by forgies
    look vip is the ultimate celica driver... He needs a section of celicatech devoted to him!
  4. #229
    Ultimo Miembro Fantįstico Gigantesco ChrisD has much to be proud of ChrisD has much to be proud of ChrisD has much to be proud of ChrisD has much to be proud of ChrisD has much to be proud of ChrisD has much to be proud of ChrisD has much to be proud of ChrisD has much to be proud of ChrisD has much to be proud of ChrisD has much to be proud of ChrisD's Avatar
    Thanks guys!! Yes definitely fun. Have only really driven it home but definitely can't wait to take it out for a good drive. Might try to hit an autocross event before the end of the year. We'll see.
    The torque dip. Can't really explain it. Will take a look at the timing map, maybe something there. TVIS was removed in this round of mods, yes. Previously it was there but controlled by an RPM switch to come on at 3400. So that doesn't even match up.
    Dual eddy current, yes. It's a Dyno Dynamics 450DS AWD unit. Not sure on the model # for the 'before' dyno. But it was a Dyno Dynamics as well. Mostly I'm concerned with the tuner first. What dyno they use is not near as important. However having an AWD dyno here was a consideration.
    Can't wait to get more boost in it. You can tell it's just getting started. I'll probably go with 1000cc injectors just to be done with it and have plenty of head room, then retune in the spring to a higher boost level...we'll see how it responds but 17 at the low end, 21 at the high end probably.
    Sent from my Transformer Prime TF201 using Tapatalk HD
  5. #230
    Mobile, AL
    I had 720cc injectors and they were maxed out at 21psi with the TD06, but that was on E85. 1000cc will give you enough head room for sure.
  6. #231
    Looking good Chris. I'm so happy you were able to get everything sorted out and make it in for a tune.
    Let me know in the spring when you are planning to book it in for a re-tune and I will book mine in the same day to get tuned. Should make for a fun day! Perhaps we could book the entire day and get a few others interested in just a dyno pull. Make it into a dyno day.
    Sent from my MB860 using Tapatalk 2
    David Walker
  7. #232
    1000CC might be a big much, it can be hard to get a good idle with injectors that big, especially if you run batch fire. An increase in fuel pressure using an inline external pump as well as ~700 cc injectors might work better.
  8. #233
    ^ true on the injector size, to a point. If you DO go big, some definitely idle better than others. Injector Dynamics are pretty darn good. My ID1000s idle far better than the old widebody 780s I had before.
  9. #234
    I've also heard good things about the ID's. I think those would be the ones to go with. I run sequential injection, just like stock on the power fc. Personally I'd also just rather not have to run lines and mount an external pump.
    Sent from my HTC One using Tapatalk 4
  10. #235
    Awesome that you finally made it out there and great to see what you managed to lay down with it.
    Well done bro!
  11. #236
    So a little update. Fixed a coolant leak, and finished off the Koni yellow strut install on all 4 corners. A bit of customization required the way I did it, but it works. Not quite as stiff as I'd hoped, sui I might be looking into coilovers or maybe custom springs of some kind. We'll see.
    Still have an oil leak to fix from the oil cooler. Hopefully that's the only one. But at least I'm able to drive it. It's a lot of fun even at this power level. Can't wait to see it with a little more boost.
    So here's the engine as it sits. Haven't polished the IC pipes or the manifold, but I'm loving how it looks. Have the new heat shield installed too obviously.
    Click image for larger version
  12. #237
    Looks awesome Chris!
    David Walker
  13. #238
    Martinez, CA
    Very nice
    Sent from my Nexus 4
    ST165
  14. #239
    Thanks guys!
  15. #240
    Took it in its first real extended drive this weekend, drove to Edmonton and back. Car performed flawlessly. Still rich in the partial throttle zones, get some backfiring, but that was expected as my tps plug wouldn't stay connected during tuning. Will just have that dealt with in the spring once I have the larger injectors in.
    Got the oil cooler gaskets/ o rings as well to deal with the oil leak, but won't touch that until snow flies.
    Here's a pic with my dad's bmw rt1200, taking a pit stop to check oil level and such.
  16. #241
    Dig it
  17. #242
    Our engine bay is next... It'll be nice to not be embarassed to open the hood :/
    '98 GS400
  18. #243
    Looking good, nice work man.
  19. #244
    You shall not pass.
  20. #245
    Clutch died yesterday. Dyno appointment June 24. Always gotta work under pressure!
    Back under the knife. Hope I can source an in stock unsprung 6 puck clutch that can get to Canada before week end...
  21. #246
    I've got an OS Giken Super Single for a 185 (not sure if there's a difference) sitting here if you're stuck.
  22. #247
    Managed to get a clutchmasters fx500 that will make it in time, but appreciate it! Going to come out to autocross at Ogopogo this year?
  23. #248
    Martinez, CA
    Looking great. How is the clutch going?
    ST165
  24. #249
    Pulled about 75% out yesterday. Should have the engine out by Wednesday or Thursday, target Saturday/Sunday to get it running. Dyno in one week.
    RacerX fuel rail and injector dynamics 1000's arrived today tho.
    Sent from my Nexus 7 using Tapatalk
  25. #250
    I hope so, but the car has been one long string of problems so I'm not committing to anything yet in the hopes that I can sneak up on it and get it to come to the Ogopogo without it knowing what's going on (and therefore not give it a chance to break at the last minute).
