Results 1 to 9 of 9
    Default Worn Piston Rings on the new 5S
    I had to take the car back to shop last night. The oil light came on, and when I checked the dip stick, I was almost out of oil. This morning I got a call from the shop, and they said that the problem is most likely worn piston rings. This shouldn't be happening to a 60000 mile engine, should it? Does it sound like they put a bad engine in the car? If the engine wasn't "brand new", wouldn't that require a rebuild?
    I'm a litte pissed right now, because I have had the car back just over a month, and there is already something major wrong with the new engine. Should I raise hell and demand a new engine, or am I making a big deal over a small problem?
    Thanks
    "...and if getting attention is your goal, this thing is even better than a Lambo Aventador with rubber tits hot-glued all over it."
    Storm
    -'92 SW21 MR2
    -'92 Celica GT Convertible
    -'92 Celica All-Trac
    tucson
    it's a big deal, if they don't fix it i'd raise hell.
    Leakdown.
    Hell, I only had a bottom-end rebuild done to correct a spun bearing (neglected an oil leak) and had my piston rings replaced. Actually, had a fun time with those, the new ones leaked -- the mechanic said it was the first time in twenty years he'd seen a new set leak, but they were replaced without charge.
    Oct 2008
    Under There
    dude, ive blown 2 engines in 6 months from some fucked up company who cant rebuild a fucking engine right...
    im getting real good at pullin my engine tho.
    Originally Posted by BabyBear
    Ive decided youre gay.
    Good day.
    be pissed
    Got the car back, they replaced the piston rings. I'm just worried about scoring on the cylinders.
    The car seems to be running fine, and I didn't see any smoke from the engine oil cover, so I'm keeping my fingers crossed. The owner told me to bring the car back in 500 miles for a full checkup.
    At least they covered the work under the warranty.
    Storm
    -'92 SW21 MR2
    Oct 2008
    Under There
    as they dam well should. im about to claim my second warranty job on my "rebuilt" engine
    Good day.
    I'm glad to see it's running. Hopefully it stays that way. Keep us posted.
