Page 10 of 10 FirstFirst ... 8 9 10
Results 226 to 249 of 249
  1. #226
    Lookin' good brother
  2. #227
    bro you nothing of my stance, its off the chart.
  3. #228
    Aint nobody got time fo dat/
  4. #229
    update!
    I swapped my 2jz in about 3 years ago with the stock crossmember and left the suspension and brakes alone also. I wanted more options and better brakes so I decided to see what I could come up with. Also I have a ford 8.8 in the back so I needed to go to 5 lugs up front as well.
    Heres the status right now
    Pulled engine
    mounted ae86 rack- I have the drawings I used for the drill pattern on the xmember if anyone wants to repeat what Im doing. just line up the old holes and center punch the new ones then bolt it up.
    mounted rack and pinion from zenki 86
    merged the stock ra29 top column with a 81 starlet bottom half, involved removed bearing carrier and welding to ra firewall plate.
    Im currently looking for the proper intermediate shaft-I hope to find one this weekend.
    As for the 5 lug.
    91 Cressida struts/spindles
    mount the Cressida lower ball joints into the ae86 lca. bolt up.
    -note you must run coilovers or smaller dia springs as the Cressida ones don't fit.
    Im also going to run the ae86 sway bar.
    As I finish this up Ill post up more pics and instructions.
    Anyway heres a parts list and some pics
    Rack and Pinion Swap
    86 xmember and R&P
    86 LCA
    81 starlet steering column
    Intermediate shaft TBD
    5 Lug
    91 Cressida steering knuckles
    91 Cressida lower ball joint
    Note-This is a rough draft, the holes are not the same as in the pic, but you get the idea.
    This pic shows the A arms
    mx83 ra29 ae86, knuckles mx83 ae86 ra29
    This is not fully welded yet, just a test.
    If anyone want to buy the old 2jz converted xmember Ill let it go cheap
  5. #230
    Heres a few more
    my 1988 4runner
  6. #231
    The hell man, are you some kind of mechanical engineer coming up with crap like that?
    Strange I know
    Now its engine mount time! again!
  8. #233
    Nice work!
    ra·tion·al·ize /ˈræʃənlˌaɪz, ˈræʃnlˌaɪz/ Show Spelled [rash-uh-nl-ahyz, rash-nl-ahyz] Show IPA verb, -ized, -iz·ing.
    –verb (used with object)
    1. to ascribe (one's acts, opinions, etc.) to causes that superficially seem reasonable and valid but that actually are unrelated to the true, possibly unconscious and often less creditable or agreeable causes.
  9. #234
    You'd better get this shit done in 7 months! Hell, you'd better get all your shit done!
  10. #235
    That is SWEET Andy. Great work.
  11. #236
    Finished the steering linkage and gear. Officially have power rack and pinion steering.
    Ignore the wiring.
  12. #237
    Got the crossmemeber and suspension done.
  13. #238
    Been side tracked by this pos. 1993 tw200
  14. #239
    Looks like a fun little summer bike. Go play on some trails.
  15. #240
    More photos
    On the mounts
    Brakes on
    Lights painted
  16. #241
  17. #242
    So you had a running driving car and you pulled the motor to convert it to a power rack and pinion and to upgrade the suspension, correct?
    What are your plans for the inside?
    “It's amazing how once the mind is free of emotional pollution, logic and clarity emerge...
    Yet, it's our emotions and imperfections that makes us human.”
    ― Clyde DeSouza,
  18. #243
    That's correct, Inside will just get cleaned and put back factory, also new headliner.
  19. #244
    I really like this
  20. #245
    I need some wheel ideas for this thing
  21. #246
    meshies all the way
  22. #247
    Mesh wheels on a 1st gen is sexy.
  23. #248
    Im still working away on this thing. Got it running and driving now. Just a few more things to finish up the front suspension and such.
  24. #249
    Formerly itsoktosmokev8s Mr. Babb is on a distinguished road Mr. Babb's Avatar
    Mr. Babb has donated to the forums! Mr. Babb helped Azzy get to The Dragon in 2009.
    Feb 2007
    Tuscaloosa, Alabama
    Looking good bro! I'm sure it's totally different feel from when I rode in it several years ago!
