    Thumbs up how to install a SAFCII in a 94 GT
    hey all installed my SAFCII today, figured id make a quick writeup on it, for future refrence...so, here it goes.
    youll need:
    10mm wrench to remove battery cable
    good soldering iron with good solder
    wire strippers
    electrical tape
    14mm socket, wrachet and extention to take out your seat if you want to.
    To wire in the SAFCII is actually really simple, it just a handfull of wires that need to be tapped into and one that needs to be spliced.
    So, lets get started.
    DISCONNECT THE NEGATIVE BATTERY CABLE!!!!!!!!!!!!!!!!!!!
    first you need to get crunched up in a ball, and wedge yourself into the little space in front of your passanger seat, look behind your center console, and find your ECU...if you cant find it, or dont know what a ECU is, STOP! you shouldnt be installing this!! hahah...or you can just take your seat out, its only 4 bolts...makes it much easier, lots more room to strech out and be confortable.
    you'll have a 26pin connector, a 16pin connector, and either a 12 or 22 pin connector depending on weather you have a manual or automatic, (looking from left to right.)
    pull out the 3 connectors, and reach behind the console and unplug the remaining connectors, and free up the harness so that you can have some room to work.
    now, take the 26pin connector in your hand, look closley at the wire side..you'll notice they have a number on each corner of the plug, coresponding to a pin # on it. find the #1, and from there follow to pin # 3 which will be a black wire with yellow stripe. this is your RPM wire(ignitor) take your wire strippers, and about 3 or 4" from the ECU, just strip back about 1/4" if the covering, without cutting the wire.
    take the green wire from the SAFC harness, twist it around the blk/yel wire, and solder it in place, then tape it up.
    next find pin # 14 on the same 26pin connector. its a brown wire. this is your ground. your gonna connect 2 wires to this wire so take your wire strippers, and again strip back about 1/4" of the covering 3 or 4" from the ecu. take the BROWN wire from the SAFC, twist, solder, tape. then about another 2 or so inches back strip another 1/4" section of covering from the same wire. take the BLACK wire from the SAFC and twist, solder, tape. THE GROUND HAS TO BE HOOKED UP THIS WAY!!!! we're done with that connector.
    take the 16 pin connector, find the #'s again. find pin #2. its a grey wire with black stripe. this is the map sensor. about 4" back from the ECU, cut the wire and strip back about 1/4" from both sides.take the side of the wire that comes from the engine bay,and twist it together with the white wire from the SAFC, again, twist solder tape. then take the ecu side of the wire, connect with the yellow wire from the SAFC twist, solder and tape.
    next , find pin# 11, its a black wire with white stripe. thats your TPS sensor. strip back about 1/4" of the wire covering, take the grey wire from the SAFC, twist, solder, tape.
    next, find pin# 13 its a clearish white wire, thats your knock sensor. strip back about 1/4" of the wire covering, take the purple wire from the SAFC, twist, solder, tape. we're done with this connector.
    now if you have a manual, take the 12pin connector (22 if its a auto) find the #7 pin (#12 for auto) its a black wire with yellow stripe. strip back about 1/4" of the wire covering. take the red wire from the SAFC, twist, solder, tape.
    THATS IT. reconnect all the plugs, plug the SAFC into the harness,and reconnect the battery, but DO NOT start the car yet. put the ignition in the "on" position make sure nothing is burning or smoking..lol then follow the setup directions in the SAFC manual. ENJOY!!
    feel free to hit me up on AIM or whatever with any questions you might have, happy to help!
    manny
    click
    for the specs of my 5sfte
    nice writeup, that was a fun install
    Minneapolis, MN
    Thanks man, going to need that soon.
    1988 CRX DX - Drag Car
    www.mydragcar.com/snafu
    Tampa, FL
    Snafu, better go ahead and check the wiring diagram for the 4AFE and make corrections to this for a 4AFE install. Some wires may be different, since this is for a 5SFE
    Quote Originally Posted by Mike431635
    this also works for a 3SFE
    but yeah, check it with the 4AFE.
    nice write up
    just woundering why no one has used a Vafc and wired the + leed that would be going to the vtec silinode to a shift light?
    95 camry 2 door
    5sfe (43,764 miles of sexyness) 5 speed
    speed MODS:Short shifter,Sold torque mount,strut bar,Power steering delete,A/c delete,Egr delete,Pcv breather,TB coolant bypass (x2),Stage 3 racing 5 puck clutch,Balancer shafts removed,balancer shaft oil galley plugged,1 off oil tray,NGK Iridium Spark Plugs .055 gap,summit street cd,4age dizzy cap,8mm plug and coil wires,summit cd coil,"cat" high flow 3sgte water pump,low temp thermostat,hyper voltage stabilizer, grounding system,Generic header,2 1/2 pipe header to muf, magnaflow high flow cat,summit turbo muf,vafc,rebuilt head (light p+P and mill .040) and 2 tb intake mani, hood spaced 3/4 inch, 255 lph fuel pump, Px3 thermal insulating Intake manifold Gasket, moog sway bar bushings, none “flamboyant” shift light
    good dood!, as for the shift light yeah that would werk, or you could control say .... vvt with it!
    Originally Posted by vafalla
  1. 92-95 Civic Radiator Install
    By whtcelionteins in forum Custom Engineering/Design/Fabrication
    Last Post: 09-18-2006, 06:39 AM
  2. Rear main Seal on my 5s (help needed)
  3. Engine install....Really need some help!!
    By Afro-Wolff in forum Naturally Aspirated Applications and Tuning
    Last Post: 04-06-2005, 08:01 PM
  4. mac performance CAI install
    By BEAMS in forum Naturally Aspirated Applications and Tuning
    Last Post: 03-09-2005, 07:56 PM
  5. Replies: 0
    Last Post: 12-01-2004, 11:41 PM
