Results 1 to 2 of 2
    Default 4afe water pump pulley question
    The water pump pulley on the 4afe has two pulleys connected together, is it possible to seperate them so there is only one pulley that runs the water pump, it looks like they may be held together with bolts but im not sure, can someone tell me if id be able to put the pulley back on and leave the inner one off? ((i dont have powersteering or ac so i dont need that inner pully ))
    It might be there for spacing purposes, so you may need to put some washers on it to keep the spacing correct as you dont want the belt to move diagonally.
    I'm not positive that that is the first thing that crossed my mind.
    2004 Acura RSX
    2009 Toyota Rav4 Sport
