View Poll Results: Was this helpful, and easy to follow?
Voters
49. You may not vote on this poll
  • Yes
    48 97.96%
  • No
    1 2.04%
Page 6 of 6 FirstFirst ... 4 5 6
Results 126 to 145 of 145
  1. #126
    I love mine. Not a drop of oil in mine
    Sent from my DROID BIONIC using Tapatalk 2
  2. #127
    Just installed one in our 165 with the help of Luni and Babybear
    '98 GS400
  3. #128
    I had one on my ae86 forever. Works great.
    Originally Posted by vafalla
  4. #129
    Yea, I'm hoping that it'll stop the oil coming out of the BOV. Or at least help it
    '98 GS400
  5. #130
    Woot! I still have mine in the 'Trac too. Works just as it should.
  6. #131
    I just picked up most of the parts today before work, Canadian style.
    Yes, you can get stuff for cheaper on eBay, but I'm all about trying my own way, especially when it comes to my own car.
    I made two stops today before work (Lordco & Home Depot), but I probably could have gotten everything at Home Depot.
    Total spent: ~$29 after tax
    Home Depot:
    Air Compressor Filter
    1/4" vacuum tube cap
    Teflon Tape
    1/4" Tube clamp
    Lordco:
    2 x Barb Fitting pipes (3/8" Hose fitting, 1/4" Male NPT ends)
    I forgot to buy the filter material itself, so it'll probably cost an extra few dollars.
    I then had to use a flat-head screwdriver to keep the valve from opening in towards the tube itself when putting the 1/4" vacuum tube cap on.
    And I pushed down the cap as best as I could.
    Voila
  7. #132
    What the heck, why is your Home Depot so much better than mine? They want $29 just for the filter here.
  8. #133
    Not sure. They should have a price matching policy as I recall from walking past the cash register. Is $29 the price that's listed on HD's website?
    http://www.homedepot.ca/webapp/wcs/s...partial&s=true
    Prices paid:
    Air compressor filter - $19.99
    Teflon tape - $0.74
    Hose clamp - $0.94
    Vacuum hose cap - $0.25
    At Lordco:
    Barbed pipe fittings - $3.14 (for 2pcs)
    Not quite sure what kinda filter to get though. What exactly am I looking for? I'll peruse around the store today before I head into work.
  9. #134
    Nicely done.
  10. #135
    Heyo,
    Just finally getting to installing the oil catch can, as my car is almost ready to be on the road.
    I'm not quite sure which hose I'm supposed to attach it to on my '94 GT-Four.
    #1 or #2?
    Also, just for confirmation, I want the airway to flow towards my air intake hose, correct?
    Cheers!
  11. #136
    You want to use whichever line is your PCV.
    The arrow should be facing the intake side, away from the engine. That arrow is meant to show which direction the air flows OUT. Hope this helps.
    -Mario
  12. #137
    Quote Originally Posted by Jeebus View Post
    Heyo,
    #1 or #2?
    Cheers!
    At least on my ST185, one of those hoses goes to the idle air control valve. I think the first one in the intake stream.
  13. #138
    Martinez, CA
    Yes #1 is the one you want to use, FYI that black box by the intercooler is a stock oil catch can
    Sent from my Nexus 4
    ST165
  14. #139
    Quote Originally Posted by jaydog82 View Post
    Are you seriousl? Haha. I had no clue. I've never read through my research that the GT-Four had a stock oil catch can. *Doh!* I'm sure there's people out there who've still done this mod on their GT-Four though. Oie, I feel a little silly for doing all this now.
  15. #140
    Martinez, CA
    It would still be nice to see how much blow buy you are getting.
    ST165
  16. #141
    This was what I discovered when I first got my car and took off the mushroom filter. I may just install it regardless!
  17. #142
    I finally got around to making mine today after I got sick of seeing blue puffs. I got the same filter as Jeebus, but I have two questions:
    1) Do I need to add a vacuum cap with that little press to open bit at the bottom? I probably will for peace of mind but I'm assuming it'll stay closed just fine so long as nothing is pressing up on it
    2) Is there anything wrong with using the filter material that came with it?
    I ended up with smaller barbed fittings but everything seems to be sealed up okay, I just had to crank down the clamp on the heater hose a bit tighter.
  18. #143
    The addition of the vacuum cap is to prevent the thing leaking out all over your engine bay as there is a small purge valve built in to the filter.
    The filter material that mine came with was a porous stone type. I suppose you could use it. Just bear in mind that it is not designed for use with oil and may well break down and get powdery/muddy and work it's way into your system.
    So if you are asking my opinion on it, I would avoid it and just use some filter material as seen throughout the thread here.
    Hope this helps and best of luck.
  19. #144
    Makes sense, thanks. One other question, I can't remember if you have to mount the can so it's lower than the PCV outlet, or if it doesn't matter.
  20. #145
    You don't have to, no. I only did because it was the simplest arrangement.
  1. simple oil catch can question
    By Keyroo in forum Forced Induction Applications and Tuning
    Last Post: 10-23-2006, 09:00 AM
  2. TECH: Oil Cooler Information
    By Adrian Avgerinos in forum Custom Engineering/Design/Fabrication
    Last Post: 10-18-2006, 06:33 PM
  3. GReddy Oil Pressure Tree
    By Trance4c in forum Maintenance, Troubleshooting, & Repair
    Last Post: 03-28-2005, 04:23 AM
  4. FAQ's: exhaust smoke by LoKi
