Results 1 to 25 of 25
    Default 4A-GE Head removal
    I tried to do a search but didnt come up with an answer. I am halfway through taking a 4A-GE apart, but I dont have the right tool to undo the head bolts. What socket is it and where can I get one?
    Cheers,
    Berg
    "If a man tries to fail and succeeds, which did he do?"
    I ENCOURAGE EVERYONE TO HAVE A FIRE EXTINGUISHER IN THEIR CAR
    My Megasquirt project:
    Junior Member Crasoum is on a distinguished road Crasoum's Avatar
    Jun 2008
    Mineola, Texas
    12 point 10mm any auto store worth salt should have it.
    Gotcha. Thanks, I've been staring at this car for three days now stripping everything useful off of it and I guess my brain shut down a little while ago. Thanks again!
    Cheers,
    Berg
    Jun 2008
    Mineola, Texas
    Ha at least you have mechanical knowledge, before I started on my Saturn and Celica the MOST I did was oil lubes, tire changes, and two brake jobs. Now I've gone full throttle and torn crap all up and down over the place.
    Everyone starts some where. I haven't any formal education (two years of high school mechanics doesn't count). The only way I learned anything was getting my hands dirty and tearing apart my first car (1979 Honda Civic Special X). Toyota's are much nicer to work on.....
    Cheers,
    Berg
    when you put that head back on make for SURE you get new cam cap bolts and a proper torque wrench for them. otherwise you will break them. I broke 2. remove head take to machine shop to remove. There cheap from toyota. and if you dont replace them you will break one. I live and learned this for you so plz do it!
    Originally Posted by vafalla
    Lol, no worries there. The head will eventually be sent off for machining and put back together with all new parts. Planning a port polish, oversized valves, new cams... the works (I'm just waiting on funds now). At that point there is really no point putting things back together with old fasteners. Thank you for the good advice!
    Cheers,
    Berg
    Jun 2008
    Mineola, Texas
    God that reminds me of the first head I took off, and put back on. As I read in my Chilton's it said 124ft/lb and was like "Isn't it inch pounds...... Oh well it's in Chilton's must be right"
    Pop. Pop.
    Helicoil became my best friend.
    I am notorious for snapping the heads off bolts. The first rebuild I ever did I tried to reuse the bolts holding the pressure plate to the flywheel. It was a weekday morning and I was already way behind schedule in getting the thing put back together. I was following the Hayne's manual for torque specs and SNAP! I was so mad I shouted out a few choice words and threw the torque wrench into the driveway. I gave the mailman a scare and got a scowl from the old lady across the street. I then had to go buy new bolts and a torque wrench.....
    Jun 2008
    Mineola, Texas
    Yea since then I've learned small bolts 120 inch pounds, big bolts 20 foot pounds, bigger bolts, more foot pounds.
    Resident Certified Toyota Mechanic Rix86 is on a distinguished road
    May 2005
    Tacoma WA
    Quote Originally Posted by andy10889
    I've done dozens of 4ag's and never seen a stretched, let alone broken cam cap bolt.
    someone did something very wrong to stretch or break on of them....
    ae86+3sgte+supra=fun........
    This is the first 4A I've pulled apart and it will be a boosted aplication... I believe that the shop I am having the headwork done at will use all new parts...
    May 2005
    Tacoma WA
    Quote Originally Posted by Berg
    If you want new parts, make sure to ask for them.
    MANY places will not put new cam bolts in, "just because".
    myself included.
    But thinking back, I'll retract my statement of never seeing one of the cam bolts stretched, on a 4ag... I have seen ONE. from another shop doin gthe head gasket and not getting it right. (they put it on upside down) :lolhittin
    Seen a shitload on the 3vze though, when other shops have gotten ahold of them.
    So waht are you going with?
    GZE pistons?
    forged?
    stock rods?
    high dollar stuff?
    There's a guy on hachiroku.net selling some 42/19 carillo rods for a good price.
    Yeah, I've been burned a couple times by shops. I've learned to get all work in writing before conmponents/money change hands. I've done the research and know what I want. Now I'm just waiting for a few paychecks....
    I'm using a big port head on an AE111 4AGZE block with US GZE pistons (~8:1 CR) machined for the oil squirters. I have a non EGR intake on its way (no strick emission laws here). T-VIS is also getting removed. Stock rods should be fine for my application. Oh yeah, I'm dropping the supercharger for a turbo.....
    Don't want to get into too much detail. I don't want to be all talk and no action. Once the build gets started I'll make a thread detailing everything.
    Cheers,
    Berg
    i was using a 1/2 drive torque wrench and shouldeve been using a 3/8
    May 2005
    Tacoma WA
    oopsie...
    Where did you get a 1/2 inch drive torque wrench that goes down to 9 ft-lbs?
    May 2005
    Tacoma WA
    Cheers,
    Berg
    word of advice... KEEP the EGR.
    It doesn't hurt performance in any wa, and increases fuel economy when driven on teh street.
    If it's a track only car... well then never mind
    Neither the exhaust or intake manifold have the holes drilled and tapped for the EGR to bolt up, and I am not going to drill the holes for them. I have removed EGRs from previous vehicle with absolutely no noticeable change in performance or economy. I've personally never liked them as they always seem to get gummed up (might be why I never noticed the difference). I also feel that the exhaust has no place in the intake (not an argument, just a personal taste thing, yes I realize that there is supposed to be an inert gas reaction causing a more consistent burn, but it can also raise combustion temperatures and I want to reduce the possibility of detonation). And I know that I am not the only one who feels that way as there are so many EGR block of plate kits out there (and the lack of them on JDM engines).
    Thanks for the advice, but this will be a non EGR engine.
    Cheers,
    Berg
    Ok, my info was wrong. I just did some net searching. The EGR will not raise combustion temp. It's sole purpose is to reduce NOx gasses. Removing it will net a cleaner engine bay.
    I'm still not putting one in because I'm not going to drill the holes and I'll be running an aftermarket ECU that won't be looking for it.
    Cheers,
    Berg
    Actually, the EGR lowers the combustion temperatures, which is how it prevents NOx from forming -- the reaction requires a great deal of energy, much more than is required to produce CO and CO2.
    Yup, I did correct myself.
    It's also only used during part throttle (and possibly startup). Still, there wont be one on this engine.
    Cheers,
    Berg
    Jun 2008
    Mineola, Texas
    As a Q, it was a 10mm 12 point, right? Just double checking, you know.
    May 2005
    Tacoma WA
    Quote Originally Posted by Crasoum
    Yes.
    And a half in drive short socket doesnt fit between the valves. I didnt try a half inch deep, but a 3/8 short worked fine (I swear, no one sells 12pt sockets in this town!).
    Cheers,
    Berg
    Jun 2008
    Mineola, Texas
    I bought mine at O'Reily's, last one they had but it was a deep socket. Everywhere I googled Said 13mm and I knew it wasn't that for my AFE. So I used playdough and a caliper to get the right size then picked the one that fit over the caliper tips.
    I figured the 4AGE was the same, but wanted to be sure so I wasn't totally clueless. Thanks.
  1. 4A head
    By jgraf87 in forum 5th Generation
    Last Post: 04-09-2007, 04:58 PM
  2. Head Removal PDF
    By Celicaguy13 in forum Naturally Aspirated Applications and Tuning
    Last Post: 05-05-2006, 12:32 AM
  3. Head, valve removal, project progress
    By angryyoungnpoor in forum Forced Induction Applications and Tuning
    Last Post: 12-14-2005, 09:50 PM
  4. 3sfe head removal
    By cgtDream in forum General Discussion
    Last Post: 11-12-2005, 03:53 AM
  5. Special Socket for head removal
    By Psyko in forum 5th Generation
    Last Post: 12-29-2004, 01:26 AM
