Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 51 to 75 of 93
  1. #51
    Quote Originally Posted by BonzaiCelica View Post
    get a 3rd gen 3sge which are dirt cheap. Or better yet buy a 3sge beams redtop. I have one myself and you will not be disappointed. Now finding a good quality used Helical LSD is going to be another thing. Get your hands on a quaife helical lsd. Brand new they cost around $1,100
    But then thats not getting more power out of a 5sfe. That's not what this thread is about.
  2. #52
    Junior Member BonzaiCelica is on a distinguished road
    Mar 2011
    Orange County, CA
    ya but honestly how much N/A power do you think you can get from a 5sfe. About 30 hp if even that. You can get a 3sge beams into your engine bay for probably $1,000 cheaper and with another 30 hp on top of your high powered N/A 5sfe. Its a fuel economic engine for crying out loud. Not worth doing a full out build at all. At that rate your 5sfe won't pass smog anyways no matter what state your in, it will only pass visual.
  3. #53
    Actually I think we have seen over 170 at the wheels on a 5s for less than a G. Not to mention your price is skewed cause there's wiring involved in a swap. The swapper has to either do that or pay for it to be done. Not to mention freshening up the engine (gaskets, seals etc) costs more. I honestly don't like the 5s either but Jeff (mrturrari) has done a lot with one for not very much. And I've driven his car and it's powerful for a 5s. It moves. This thread is there to give people an option. If they want to build their 5s they can. If they want to swap they can.
  4. #54
    Mar 2011
    Orange County, CA
    no way 170 at the wheels I call bs. 4th gen 3sge can make 170 whp in stock form.
    So your telling me you've seen someone put on an additional 65 hp in N/A form? Do you have specs?? I'd like to see it.
  5. #55
    What do emissions have to do with it?
  6. #56
    Martinez, CA
    iv gotten a 5s up to almost 150 hp for pretty cheap, 2rev head with a port n polish and head shave- cold air intake-cat back and header- 30 degrees of timing-along with a full rebuild and a stage 1 clutch. i never had it dynoed, but there was a very big difference from stock.
    ST165
  7. #57
    I guess I was wrong, mrturrari said 147 to the wheels.
    Anyway hes aware that he can do an engine swap or this or that. That isnt the point of this thread. Wanna talk about your beams, or 3SGE? Go start your own thread.
  8. #58
    Go brag about your beams in another thread.
    This is a 5sfe thread.
  9. #59
    Ultimo Miembro Fantįstico Gigantesco MrWOT has much to be proud of MrWOT has much to be proud of MrWOT has much to be proud of MrWOT has much to be proud of MrWOT has much to be proud of MrWOT has much to be proud of MrWOT has much to be proud of MrWOT has much to be proud of MrWOT has much to be proud of MrWOT has much to be proud of
    I have yet to see a cam'd 5S with a good header/collector. N/A needs overlap scavenging to get the intake moving. Still power left on the table.
  10. #60
    I had a CAI, header, 2.25 in exhaust, 10.5:1 compression ratio, port matched head/intake manifold, cams, and an SAFC. My old 5sfe was quite a bit faster than stock.
  11. #61
    Even though I'm new here, can I weigh in just quickly? Without going into forced induction, 3sgte swaps, overall costs, blah, blah, blah, blah, I would just like to say why I have chosen to upgrade my 5sfe. Please keep in mind that I'm a married, 34 year old father w/ 2 kids. Although I love fast cars (every man does, or at least should) they are not my priority in life right now. I am not an 18 year old ricer living w/ my parents and trying to play "2 Fast 2 Furious."
    1. Although I'm very mechanically inclined, and own lots of nice tools, I am not incredibly experienced at working on vehicles. I have no immediate desire to rush into ordering an entire motor, rebuilding it from the ground up, deal w/ compatibility issues, rewiring harnesses, etc. I CAN however, handle installing a new header myself, swap out the head, install and weld an exhaust, etc...
    2. I can't drop the amount of money required on a used engine, front clip, machine shop costs, new full engine gasket sets, pistons, rings, ecu, etc, etc, etc. I CAN however, afford to order a header online, install it on the weekend, and then order a SRI next month and install it. Am I going to end up w/ a 600HP street monster? No, I have no illusions about this, but every month my car gets a little peppier, and a little more fun to drive, and I'm LEARNING more and more about it as I go, which hopefully in the end might get me to the confidence level where I would consider an engine swap.
    3. My car is now 21 years old, and it has over 300k on the clicker. I have to accept the fact that although I would LIKE to through all my spare money at it and see what happens, I also have maintenance costs. So that spare $150 doesn't go as far last month, for example when I needed a new fuel filter.
    I can't get over how many idiots continue to argue on this thread. His thread wasn't WHETHER or not you should, or WHICH engine would be better to use in the long run, or WHAT was the best route to take if you had an extra 3k in the bank, and 2 spare weeks to work on your vehicle while it was down, AND an extra vehicle to drive WHILE it was down. This thread is about HOW to get more power from a 5sfe. Period. I have enjoyed reading it, have learned from it, and plan to benefit from someone who obviously has an excellent knowledge of this engine. Everyone else can pound sand.
    1990 GT
    2.2l: odometer stopped at 257k miles!
  12. #62
    Oct 2006
    Minot ND
    I love you
    Originally Posted by manda
    89 Celica GT
    88 ST165 "
    07 4Runner SR5
  13. #63
    If you've got cams, and a header, add a 2.25" diameter ~20" long (length adjusts rpm range) collector at the end of the header. Without a collector you're getting no scavenge on overlap.
  14. #64
    I had a collector on mine.
  15. #65
    I don't count those ebay style things as headers at all. Made of U-bends, nice merge section, or gtfo. Mine cost me over $400 to make on my 3S
    edit: They probably flow better (reduced backpressure) vs. the factory manifolds, so they aren't a complete loss, but the are not a "header".
  16. #66
    Nah, I had the camry header. Doesn't have the long runners but it did have a collector. Probably better than that ebay one though.
  17. #67
    Thats right bitch so better recognize!
  18. #68
    Martinez, CA
    1st gen jdm 3sge 4-2-1 header
    ST165
  19. #69
    Oct 2006
    Minot ND
    I have a 5s and a 4-2-1 3s laying around. havent decided which to use yet
    89 Celica GT
    88 ST165 "
    07 4Runner SR5
  20. #70
    I'M KILLING IT k.beaty is on a distinguished road
    k.beaty has donated to the forums! k.beaty helped Azzy get to The Dragon in 2009.
    May 2008
    Hamilton, ON
    I've got my hands on a TRD Pro/Celebrity header. These were designed by TRD and used only on the Pro/Celebrity cars. They were never put into production. These are pictures that the previous owner sent to me, I have since cut the end of it off right before the exhaust clamp and had a flange welded on.
    Kyle
    1990 GT-S - Diamond wheel OG
  21. #71
    Thanks guys for all the comments and correcting a lot of the misinformation out there. That is one of the reasons I like CelicaTech is there is much more openness to new ideas here and support for those who want to try things. It's one thing to give someone feedback on their ideas and completely another to just shoot them down out of hand with no thought into their situation and goals.
    As Sopaynefull said, some of us just want a working car that we can mod a little at a time rather then sink a ton of cash and effort into it all at once.
    Some of us also enjoy the journey and rewards of designing and building something ourselves. I have owned the 5sfe in my Teal MR2 for 7 years now and have had about 6 months of total down time, most of that because of mechanical failures or relating to my 5sfte efforts. My other 5sfe, I have had for 4 years and it has not been down for more then a couple of days at a time. That car has all bolt-ons and makes somewhere between 130-135rwhp (155-160 at the crank) and I have spent a total of about $350 (Delta cams, homemade header, Turbo MR2 exhaust). That is as much power as a gen2 3sge with more torque. I realize that some can't do it as cheaply as me but it can still be a pretty good bang for the buck.
    FYI, Jim Snodgrass made 147rwhp but also only had one cam upgraded and it was only a 294 grind. He ran an EMS and 4-2-1 header though and did some mild head work. No one has yet dynoed a 5sfe with high compression, performance cams, custom intake manifold and purpose built header so you won't see BEAMS power levels until that happens. And by the way every stock BEAMS dyno I have seen puts power at 160rwhp which means Jim with his mild cam and stock intake manifold was just 13rwhp away. That is of course if you just want to consider peak HP numbers which can misrepresent how fast a car really is.
  22. #72
    Quote Originally Posted by MrWOT View Post
    That's not entirely true but I am assuming that you are trying to make a point. A collector amplifies the pulses so they can be more effective. You can still have scavenging even if the primaries empty right into the exhaust pipe at odd angles or abruptly. Much better to have a good collector then not though.
    Quote Originally Posted by k.beaty View Post
    That is one of the better designs I have seen. Looks like a very well thought out piece.
  23. #73
    That TRD header looks like a copy of the Tanaka (JDM) headers
    The Gen1 GE header pictured is an early type, the better later type has longer pipes and a curved manifold
    Price/performance you can't beat the gen2/3 GE headers
    From my experience the FE exhaust is too small to make full use of better headers
    The quickest/cheapest route to FE power is to use the later head/manifolds/pistons, each gen got more and more power
    Later head has more ribs in front and makes a lot more power -
    Early porting is tiny compared to later type head
    Later cams have much more lift & duration, probably not a good idea to use with the early head and pistons
  24. #74
    Quote Originally Posted by MrTurrari View Post
    No amplification takes place. The collector is there because you have to have a certain area change in order to maximize the reflection amplitude, but it will never make it stronger than the original wave. Without a collector you may have low backpressure, but you aren't scavenging (not enough energy), we're talking a difference in amplitude on several orders of magnitude. It is the area change that is most important.
    edit: on a side note, you can make a surprisingly effective header by having short stacks (maybe 4"-10" long from the head flange) feeding into a large tube (8" diameter) at an angle that promotes exit to the tailpipe. I've seen results off these "log" style manifolds that rival the best headers. But they don't serve the same purpose, trading general-all-around low pressure for a tuned range. I'm making these for my regal gs since I value the band more than a tuned range with the blower on it.
  25. #75
    Amplify is probably a bad choice of words on my part. The shape of the collector can restack the pulse so that it is more focused or less focused. The amount of energy doesn't change but it's duration and amplitude can alter relative to what came down the runner in the first place. The collector itself is another secondary length that has it's own reflections. A collector with rounded or triangular primary entry points will soften the pulse and spread it out over time including the negative wave that immediately travels up the other runners. A tapering down collector pipe will cause the wave to compress as it reflects into a shorter duration and give you a higher peak. It works similarly to a velocity stack but in reverse. Any time there is a change in pipe sizer there is a reflection. The trick with both secondaries and collectors is to get them in sync with the primaries so you aren't cancelling out the effects.
  1. List of 7th Gens.
  2. probably ditching 5sfe for V8 power
    By Hookecho in forum Custom Engineering/Design/Fabrication
    Last Post: 03-13-2008, 10:59 AM
  3. Turbocharging my girl's ride.
    By Gigabelova in forum Forced Induction Applications and Tuning
    Last Post: 12-14-2007, 03:26 AM
  4. Power graphs for 3SGE & 5SFE?
    By 88GT2GTS in forum General Discussion
    Last Post: 05-17-2006, 04:58 AM
