Results 1 to 20 of 20
Thread: Won't run
    Default Won't run
    I have an 87 GTS, 5spd. It sat for a week in about -25 celcius and when I started it it ran for 5 - 10 seconds and then sputtered out. Now it cranks strong (has a new starter), but won't fire. Two plugs are wet with gas and one is dry (I didn't check the last), they all have good spark. I took the top cover off the timing belt as best as I could without removing the motor mount (it didn't seem to want to come off without removing that) and the belt isn't broken, it kind of seems a little loose, but not too bad. Distributor looks alright. I don't have a timing gun. Anyone care to give ideas? Timing belt jumped? I'm not familiar with the Celica yet, any sensors that could be bad? Thanks
    Would some one care to answer this I have a 86 that is doing the same thing it is very irritating i think the longest it has run is two min and if you touch the throttle it stalls..
    Murg's Heathen's Pet Snitch Monkey CollapsedNut is a splendid one to behold CollapsedNut is a splendid one to behold CollapsedNut is a splendid one to behold CollapsedNut is a splendid one to behold CollapsedNut is a splendid one to behold CollapsedNut is a splendid one to behold CollapsedNut is a splendid one to behold CollapsedNut's Avatar
    CollapsedNut has been to an annual Dragon Meet! CollapsedNut has donated to the forums! CollapsedNut helped bring Chaos back to the Dragon
    Oct 2006
    Minot ND
    Timing belt shouldnt be the problem. If the car ran fine before you parked it, cold weather would only make the belt get tighter. I highly doute it jumped time.
    You say you have spark. Ima assume its getting air, then that leaves one thing. Fuel. Chances are you had some water in your fuel, the cold weather froze it, if its still cold it may still be frozen, clogging the line. If its warmed up, the frozen water may have ruined something.
    Most fuel rails have a valve kinda like the valve on your tire. I could go look at my 4th gen, but I just came in. Have someone turn your key to the run position, do not start, while you hold the stem of the valve open, much like you would to let air out of a tire. See if you get fuel coming out there. Lemmi know what happens and we can go from there.
    This is the most likely condition, I see it every day. To help avoid this make sure you keep a full tank of gas when you know its going to be very cold, this reduces the chances that water will be in the line, and that will keep it floating up on top of the gas away from your pump.
    Originally Posted by manda
    what do I know? I'm just a woman on a car forum..
    guess I better get back to makin your sammich
    Cheese! Cheese for everyone! Wait..no. No cheese for you!
    89 Celica GT
    88 ST165 "
    07 4Runner SR5
    Check the maf, clean em up. Could be air leaks as well (intake, etc).
    I'll check the fuel rail "valve" and maf tomorrow. I did try and start it again yesterday since it has been warm for the last few days and it did the same thing - cranks strong, maybe even a little too easy, but that could be my imagination. I pulled all the plugs again and they are all wet with fuel. I'll check for spark again too tomorrow.
    it is low on gas and I have the owner bringing me some more gas. Also the motor has not been apart but instead has been a transplant. it was ordered and shipped to us and we dropped it in. I have played a little with the mass air and doesnt seem to make a difference. If the car sits for about ten seconds and i try it again it fires right back up to stall back out. I was just curious to see if there where any tips or tricks to try. I am more of a honda man my self but this car intrigues me and i cant leave it alone until it runs..
    Thanks for the help
    sorry for the thread hijack. Just figured that we were having a similar problem why create another thread..
    Drove all the way to TN, for the hotel. CriScO has a reputation beyond repute CriScO has a reputation beyond repute CriScO has a reputation beyond repute CriScO has a reputation beyond repute CriScO has a reputation beyond repute CriScO has a reputation beyond repute CriScO has a reputation beyond repute CriScO has a reputation beyond repute CriScO has a reputation beyond repute CriScO has a reputation beyond repute CriScO has a reputation beyond repute CriScO's Avatar
    CriScO has been to an annual Dragon Meet! CriScO has donated to the forums! CriScO helped get Grayscale's Celica towed from The Dragon in 2008. CriScO helped Azzy get to The Dragon in 2009. CriScO helped bring Chaos back to the Dragon
    Golden, CO; Azz's Pants
    Have either of you checked compression?
    The Coupe:
    - Custom SRI, external coil distributor conversion, MSD Blaster 2 coil, MSD 6a ignition, OBX 4-1 Header, 2.5" exhaust with Magnaflow muffler, Eibach springs, GT-S hub/rear disc conversion, Lots of shiny red engine paint, Ridiculously unnecessary 5" tach, Tons of fun useless switches and pretty glowing red lights, Currently sitting in the driveway with a snapped timing belt I'm too lazy to fix...
    The Hatch:
    - Custom SRI, External coil distributor conversion, Accel performance coil, Hayden transmission cooler, ASI dual-core aluminum ST165 radiator, Some shiny black engine paint, A few glowing red lights, Temporarily downgraded to daily driver status...
    If the plugs are wet with fuel I would think that means you may not be getting good spark. I would suggest getting a cheap spark checker just to rule it out. Also maybe pull the plug itself and see if it is actually sparking.
    Oct 2006
    Minot ND
    Yeah I didnt think about that. Even tho they are wet, they may not be getting enough fuel and that would explain the sputtering. Its hard to tell without being at the car.
    89 Celica GT
    88 ST165 "
    07 4Runner SR5
    we have checked the compression. He has narrowed it down to a fuel problem today while I was at work. The pump primes then shuts off and doesnt come back on until you turn the key off and back on. This has me wondering if there is a main relay some where that we dont know about??
    Just the EFI main in the compartment right next to the battery.
    The Coupe:
    The Hatch:
    ok guys finally got some time to mess with this thing seems like the injectors are not fireing I have two ecus and they wont fire with either ecu??? Im really scratching my head here what makes the injectors fire on these motors? I know the cold start one is working because letting the car sit for a few min it starts then shuts off. I have jumped the fuel pump so it runs any time the key is on and still no go. How ever we can keep the car running if we spray starting fluid/carb cleaner in through one of the vaccum ports.. I have checked the ignition switch and it checks out. I have chased down wire after wire but I am out of options...
    The ECU grounds the injectors.
    Check for 12v with the key on at the black/orange or black/red wire [I can't remember which color it is].
    the other wire is going to be the ground, which the ECU switches on and off.
    If there's 12v at the injectors with the key on plug the connectors back in, leave the key on and check for 12v at the injector wires going into the ECU. Leave it connected.
    *Sorry, I didn't put the black/orange [Thanks Crisco ] wire at the injector connector. The other injector wire goes to the ECU and is grounded internally when the injector is supposed to open.*
    Black/orange is the ignition/fuel positive.
    The Coupe:
    The Hatch:
    Senior Member v8killer is on a distinguished road
    Feb 2007
    Hollister, California !!!!!
    try putting a quart of acetone or MEK in the tank if your in cold weather with a dirty fuel system and not enough fuel it might help to have a bit more atomization. check the resistor pack as well. and of course what was mentioned above
    black st165 sleeper- the v8 killin' 2.0L bottle of whoop-ass!
    mods: you wish you knew!
    "Straight lines are for fast cars, turns are for fast drivers" Colin McRae- RIP
    Originally Posted by Luni
    Are you serious?
    Jesus, you really should just get a fucking sportscar that was designed to go fast.
    It doesn't have a resistor, which is why it wasn't mentioned..................................
    I hate to argue with the first post on here, but Ive personally had a timing belt jump time in bad weather. The pulleys got stiffer harder to turn, the rubber got harder and more brittle, something happened, but it was PearlJammzz car on here, however it was a 5S, but his was the same boat. He parked his car, went to start it a few weeks later to keep the engine happy throughout the winter, and bam wouldnt start. Got the car towed to my house in the spring, had to reset the timing belt.
    Feb 2007
    hrmmmm...... i know on the 88-89 there are. well guess i learned something new
    Are you serious?
    Quote Originally Posted by v8killer View Post
    No they don't.
    1st gen 3SGEs don't have injector resistors, 87, 88 or 89.
    Quote Originally Posted by Luni View Post
    Definitely could be, I've seen it happen too.
    Feb 2007
    my bad, may have projected that from seeing my alltrac have the resistor pack in the same looking engine bay.
    Are you serious?
