Thread: cracked rim
    tucson
    Default cracked rim
    so this past month's been pretty bad. my old black rims are toast. two rims are good. one is bent, and the other is bent and cracked. so i picked up a set of racking hart c4 rims. i recently found out that i have a small fracture along the edge of it that leaks air pretty bad. takes about 2 hours to go flat. i called a few places and found only 2 places that fix cracked rims and even then they have to be see the rim to tell me if they can fix it. =(. have u guys ever had a rim repaired a cracked rim and if this a reliable fix or will it still be not as strong as the rim once was?
    I now a guy who used to do it for a living. Fixed Ferrari rims that cost $6 grand. If they say they can fix it, they can. They'll weld up the crack, machine the weld down and repaint the wheel. It's not cheap. Usually if the rim costs less than $150-200 new, they'll tell you to buy a new rim.
    tucson
    its not scuffed or anything though. so i wonder if it'll be cheaper.
  1. cracked windshield
    By Unarmed in forum Maintenance, Troubleshooting, & Repair
    Last Post: 02-25-2008, 04:26 AM
  2. Downpipe cracked ! Now what?
    By Shadowlife25 in forum Forced Induction Applications and Tuning
    Last Post: 02-15-2007, 04:11 AM
  3. overheating 4afe - cracked exhaust mainfold
    By heyman in forum 5th Generation
    Last Post: 06-26-2006, 02:45 AM
  4. Lug nut cracked :ouch:
    By AllOutRed90 in forum Brakes, Tires, & Suspension
    Last Post: 08-16-2005, 05:18 PM
