Thread: Help Me!!!
    Exclamation Help Me!!!
    Hey guys ! i have 1988 GTS Celica 3s-ge motor !!!
    When i take off its fine but when it hits around 3500rpm after that seems like there nomore power!!! the clutch is fine was just replaced! 3500 Km ago! and max i have gotin it was up to 80 km floored! in 4th and i tryed down shifting and still 80 floored!
    Im thinking its a o2 sensor,MAP Sensor!
    also the throttle body screw is 1/4 turn open if i open it any more it idles way to high!!! i have checked for vaccum leaks cant find any!!!! help!
    Well tell you what! as i was test driving to see if i have fixed the power problem couple of bolts came out well i turned around and went home! and i jacked up the car and i see that there the engine mount bolts!!! also the support member going from gas tank to front wasnt bolted on! after i put the 2 bolts were they needed to go plus that other bolt!!! it had way more toque!
    nOW I timed it to 10Degrees! as it should be ~! but my rpms are high 1300rpm plus its really RICH!!!!! How can i adjust the fuel amount! Or is there a way to reset it!
    Oct 2005
    Cranston, RI
    If your running RIch you should adjust your timing accordingly. Do you have a fuel pressure regulator. This will help!
    She's sold
    i did its at 10 degrees and it still !!! also idles high!!! maybe i have to reinstall the disrpubotor
    were would that be located fuel pressure reg?
    If it's still idles high, adjust the idle speed screw.
    88 ST165...All-Trac
    89GTS...Ol' Faithful
    86GTS...my 3rd Celica
    Hey gues whats this?!
