Results 1 to 25 of 77
    Default My CS/RC Bumper Install - LOTS OF PICS
    Hi Everyone,
    I finally decided that my daily driver needed one last exterior upgrade so I decided to jump on the wagon and get a CS/RC Bumper. I bought the bumper from 1sttoyotaparts.com. Price was reasonable and shipping was fast. The only thing I bought was the bumper cover. I did not purchase the CS reinforcement bumper as I do not need to ever install a huge intercooler on my N/A engine.
    I recall there being questions and debates whether the CS bumper will fit over the stock reiforcement crash bar. Well, to answer those nay-sayers, IT DOES FIT OVER. All I did was dremel out a few tabs that were sticking out of the back of the bumper and it fits like a glove.
    Don't be too intimidated about removing the front bumper. Just take your time and use your common sense and you'll be fine. Of course, don't forget to disconnect the battery just in case. It is also helpful to jack the front end up and place the front end on jack stands.
    Note: I am not liable for any damages. (Can't forget the disclaimer )
    CS/RC Bumper Cover Part Number 52119-20929
    Tool List
    - Screwdrivers
    - Rachet and 10mm, 12mm, 14mm sockets
    - WD-40
    - Rivet Gun for compatibility with 1/8" rivets
    - 1/8" x 1/4" Rivets
    - Dremel
    Let the removal begin!
    Here is what my GT-S bumper looked like straight from the factory.
    Blurry engine shot
    Removing the corner and bumper lights...note, if you do not know how to remove these, then I suggest you do not attempt to remove your bumper Also remove the front plastic (fake carbon) grill.
    Remove the plastic radiator cover by removing the round clips (just press the center of the clips inwards)
    On the upper radiator support, you can see that the bumper is bolted on to it by the bolts on the 3 black brackets. (One in front of each headlight and one in the center) Remove these bolts.
    Remove the clips and bolts that connects the underbody cover to the bumper
    Remove the bolt behind the corner lights and the bolt on the bottom corner of the bumper.
    Dismantle the front lower grill if you have this Alltrac/GT-S bumper and remove the foglight grills. Also remove the license plate bracket and remove the miscellaneous clips and bolts in the grill that mounts the bumper on.
    Once you're certain that all of the bolts are removed, pop the sides of the bumper outwards away from the car. The sides of the bumper is held on by clips. Be careful not to damage anything. If you're lucky, you're old bumper should come off in a snap (not literally)
    Remove the foglights
    This is where the dremeling comes in...
    Dry fit your CS bumper over the stock crash bar. You will notice that the top part of the bumper doesn't go in as far as it should. This is because of the small extrusions or tabs on the back side of the bumper. I believe this is for mounting the mesh grills that are available at the dealer.
    As you can see in the pictures, I only removed 4 tabs. Just use your judgement as to which ones to dremel out and you should be fine.
    Dry fit to check for proper clearances
    You are going to need to swap over all of the brackets and clips from your old bumper onto your new CS bumper. One set of these brackets is the important side brackets. You don't want your sides to be popping out so this is critical for a good fit.
    Have you ever used a rivet gun before? I haven't but I learned in a few seconds. (Engineering skills :ohyeah: ) Go purchase a cheap rivet gun for 10 dollars and a few 1/8" x 1/4" rivets. Carefully dremel out the old rivets on the side bracket to remove it from your old bumper. Rivet on the side brackets to your new bumper.
    Once you swapped over all of the brackets and mounts (don't forget the front bumper lights screw clip) installation is just merely a reverse of the removal.
    BTW, my bottom underbody engine cover did extend to the CS bumper and did not fall short. Might be different for other models...
    Looks a lot better in my opinion, but I'm missing those large stock foglights. I need to find some foglights now. Any suggestions??
    1993 Celica GT-S - Eibach ProKit, Alltrac Hood, CS Bumper, JDM Clear Corners, Clear Front Bumper, 35% Tints, Kicker RMB8, Lenso Samurai Bronze 17" Wheels
    2007 GTI - NewSouth Boost Gauge, APR Stage 1, Neuspeed P-Flo Intake
    Front shot, level with the bumper/license plate holder please?
    Quote Originally Posted by Galcobar
    Definitely, once I get a hold of the digicam I left at my parents house. Are you looking to see what the stock crash bar looks like through the bumper? It's black so it's not too noticeable. Most people don't notice unless I point it out.
    Here are a few other pictures I have on hand...
    Ultimo Miembro Fantástico Gigantesco geebes is a splendid one to behold geebes is a splendid one to behold geebes is a splendid one to behold geebes is a splendid one to behold geebes is a splendid one to behold geebes is a splendid one to behold geebes is a splendid one to behold geebes's Avatar
    Oct 2005
    Spokane, Wa
    Looks good cheif!
    Right, Brilliant, Cheers!
    Washington & Oregon
    Nice work, interesting about the underbody panels. I may have to buy some new ones then.
    2007 Range Rover Sport HSE
    Yeah, I was afraid that the undercover wasn't going to reach the new bumper, but to my surprise it did. I guess all you would have to get is an undercover from a 92-93 GT-S or from any ST185.
    I had to remove the metal bracket of the undercover that bolted up to the stock bumper, but I just tucked the underbody cover over the bottom back edge of the CS bumper.
    very nice work.
    Good write up, car looks much improved.
    Mar 2006
    IL
    Very nice, what did you use to paint it?
    2000 Subaru Impreza 2.5RS
    Quote Originally Posted by Cavanagh
    I didn't paint it. I had my cousin paint it for me for cheap.
    I was considering painting it myself, but I felt that the materials and tools required to paint just the bumper would exceed the price to have it done by a professional shop.
    good write up! looks sweet!
    maybe a sticky??
    Very nicely done. Concise wording on the write-up as well. Thanks
    Quote Originally Posted by AznKlique
    Did you ever happen to get this photo? I despise how the licence plate mounts on my 90 GT bumper and figure it would look a lot cleaner with a CS bumper -- but am concerned about the visibility of the stock crash bar.
    great write up. lots of helpful information. looks sexy and very nice touch.
    Sorry, not yet. It's been rather nasty out for the past few weeks. I'll see if I can get a pic up today.
    Well, I tried to post up some pics on how the crash bar looks behind the bumper on the second set of pictures I posted. You don't even notice it because it's painted black. Blends in well actually.
    Did the holes on your undercovers match up as well? MY undercover extended too far for the RC bumper.
    Quote Originally Posted by cms-gt4
    The holes didn't match up. I tucked the underbody cover over the bottom lip on the backside of the bumper. Seemed stiff enough to stay in place even at high speeds
    clean looking sharp
    YouTube- Celica Rally Tribute
    Streetfire-Celica Rally Tribute
    Where did you get your bumper, if you don't mind me asking. I need to either fix my bumper or replace it. Found them online from various "toyota part warehouses" with crapy websites for $211, but would be willing to pay more to get it from a more reputable source...
    I'm gonna stop at Brunswick Toyota tomorrow and see what they charge
    Am I being detained officer? tuner4life is a name known to all tuner4life is a name known to all tuner4life is a name known to all tuner4life is a name known to all tuner4life is a name known to all tuner4life is a name known to all tuner4life's Avatar
    tuner4life has been to an annual Dragon Meet! tuner4life has donated to the forums! tuner4life helped get Grayscale's Celica towed from The Dragon in 2008.
    Oct 2007
    Indiana
    1sttoyotaparts.com
    There is a thread for the part numbers on the forum somewhere
    Part number for bumper and place I bought it is in my first post.
    Jun 2005
    Northern Indiana
    First Toyota kicks ass.
    I get stuff for my SC300 all the time there using assorted MKIV Supra parts.
    --Aaron
    Oh wow, I read your post and saw the part numbr but somehow totally missed the part about 1st toyota.
    Did you paint the bumper yourself or have somebody else do it?
    I think I can install the bumper thanks to your concise wright-up, but I wouldn't confident in painting it.
    ::edit::
    Nevermind, I gotta start reading things better.
    If you have any questions regarding the install, just let me know. I left out a couple of things, but they should be self explanatory once you get rolling.
    I take it you got some fog lights?
  1. 3 Peice Spoiler Install and random pics.
    By andy in forum General Discussion
    Last Post: 10-12-2007, 11:07 AM
  2. How To: Install Clear Corners on Molded Front Bumper?
    By TEAMFaint in forum 5th Generation
    Last Post: 05-10-2007, 07:27 PM
  3. 56k waring...My gt-2 in detail... write up with lots of pics
    By 3S-GTE_Man in forum Australia , New Zealand and Pacific Countries
    Last Post: 05-03-2007, 02:54 AM
  4. Rear main Seal on my 5s (help needed)
