Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 26 to 50 of 119
  1. #26
    the stock 5sfe valves are just plain tiny. with the size of the ports a 2mm os valve should be right on target. the 5sfe port size is way to big for the stock valves.
    5sfe intake valve - 32.5mm
    5sfe exhaust valve - 29mm
    3sgte intake valve - 33.5mm
    3sgte exhaust valve - 30mm
  2. #27
    what needs to be done to get those 3sgte valves to work on the 5sfe?
  3. #28
    just have the valve seats reground.
  4. #29
    shaun @ MCS can do a FULLY built 5s head for ~ 1500, + whatever cams you send him...lemme see if i can dig up the email....here it is:
    As for headwork, we can use oversize 3S valves (we machine them to fit). We could open the head up with a STAGE III Port and polish work coupled with some beefier springs, and your custom cams. Costs are the same as for 3S work.
    MCS STAGE III 5S Superflow Head: $1475
    STAGE III P&P
    Ferrea 1mm OS valves
    Engle Valvesprings
    Customer spec Cams (install)
    click
    for the specs of my 5sfte
  5. #30
    MCS linky?
  6. #31
    click
  7. #32
    here's some basic info on camshaft types, lifters, and specs.
    Let's start with the types of cams and lifters that are available:
    FLAT TAPPET CAMS are cams designed for use with either hydraulic or solid lifters (but not both) with a bottom surface which is nearly flat. I say nearly flat because these lifters are actually slightly convex in shape. When the convex surface of the lifter matches with the slightly angled surface of the cam lobe (the portion of the camshaft that creates valve train movement) the lifter will rotate in its bore. If the lifter doesn't rotate for any reason the cam and lifter will wear out very quickly.
    HYDRAULIC lifters use the engine's oiling system to automatially adjust the valve lash (clearance) to zero. They are the most common type of flat tappet cams and lifters for street use. Hydraulic cams can use any one of the three types of these oil filled lifters.
    Stock type hydraulic lifters are quiet running and require little or no adjustment after installation but are limited in performance to about 5500 rpm. The ANTI-PUMPUP lifter is a type of hydraulic lifter that will rev higher but requires adjustable valve train components. VARIABLE (also known as Vari-Duration) hydraulic lifters are the next step up from anti-pumpup lifters. They improve low-end power and permit higher rpm use without the requirement of valve adjustment. RHOADS is the original manufacturer of variable hydraulic lifters and still makes the most effective ones.
    MECHANICAL or SOLID cams use a solid or oil control flat tappet (lifter) which requires regular valve adjustment. Some performance shops prefer solid lifters, even for street use, because they can adjust the way a cam will perform to a limited extent by changing the amount of lash (clearance) in the valve train. Decreasing the lash increases the duration and lift, increasing the lash decreases the duration and lift. For race use solid lifters will perform up to about 8500 rpm.
    MUSHROOM lifter cams use solid lifters that look similar to an upside-down mushroom. The base of the lifter (where it contacts the cam lobe) is wider than the body of the lifter. These are used mostly on oval tracks when roller lifters aren't allowed. Block machining at the bottom of the lifter bores is required.
    ROLLER cams, as the name implies, use a lifter with a roller as the surface that follows the cam lobe. The roller surface allows very precise valve movement, as well as reduced friction, permitting a much wider operating range than is available with a flat tappet cam. Hydraulic roller lifters are common in late model engines and a variety of performance cams are available. They are as quiet and maintainance free as flat hydraulic lifters. Solid roller lifters are used mostly in highly modified race engines although there are a couple available for "pro street" applications. For maximum rpm use a solid roller design is definitely the best choice.
    Now that you know the advantages and disadvantages of the various types of cams we can look at what all of the specs mean.
    DURATION is the lenth of time that the valve is held open by the cam. This is measured by the degrees that the crankshaft rotates. More degrees of duration will make the engine operate in a higher rpm range. There are two ways of rating duration.
    Advertised duration was originally the S.A.E. (Society of Automotive Engineers) standard as measured from .006" of valve lift. Over the years this has been altered by most performance cam makers to make their cams look hotter, or different, than the specs of their competitors. Valve lift points as low as .002" are sometimes used and this can add up to thirty degrees to the advertised figure. Even when the cams being compared are all measured the same way the figures can still be misleading if you don't know what the cams were designed for. Cams designed for quiet street operation will show higher .006" duration numbers than performance cams of the same rpm range.
    Duration measured from .050" of cam lift is the best for comparison of specs because most of the variations in cam design are reduced and the valves are open enough to start getting some flow past them. Most cam makers give accurate .050" ratings and good comparisons are possible between cams of the same type (hydraulic or solid or roller).
    LIFT is usually measured as gross (total) valve lift. This works for hydraulic lifter cams but is misleading for solids and rollers because you must subtract the valve clearance to get the net (real) valve lift. Cam lift is sometimes given and is just the lift of the cam only before the rocker ratio is figured in.
    LOBE AREA is obtained by measuring the lift at each degree of rotation and adding them all together. This will tell you very quickly how much difference (if any) there is between two cams with the same lift and duration. This is rarely supplied by cam makers.
    LOBE CENTER is the degrees the crankshaft turns from top dead center to the center of the top of the cam lobe. If you add the centers of both cam lobes together and divide by two you will have the lobe center separation.
    LOBE CENTER SEPARATION is the degrees the cam turns from the center of the exhaust lobe to the center of the intake lobe on the same cylinder. Wide lobe center separations (114) give minimal valve overlap on street cams under 220 degrees at .050". This produces high manifold vacuum for street engines. Closer lobe separations of 108 degrees willnot allow computer engine controls to function properly but will give better mid to high rpm performance when used in carbureted engines.
    VALVE LASH is the amount of clearance required at the valve tip with solid and roller lifters.
    VALVE TIMING is the opening and closing points of the valves measured in relation to the degrees of crankshaft rotation. These specs are often given by both the advertised and the .050 methods. These points can be advanced or retarded (as a group) after installation with a multi-keyway crank gear, offset keys, or special bushings.
    That covers most of the terms that you are likely to hear when you are shopping for a new camshaft. It's good to know what all of the information that is available means but the specs and technical descriptions are only part of the story. Some cam manufacturers will also include comments about the intended use and rpm range of each cam in their catalogue. Often these comments give information that wouldn't otherwise be apparent by checking the specs only.
    Here are a few more terms that, while you will not need to know them for selecting a cam, you might come across during a "bench racing" session.
    ASYMMETRICAL CAM LOBES are designed with the closing side of the lobe different in shape than the opening side. This difference is only visible in some overhead cams. When both sides are the same they are SYMMETRICAL.
    BASE CIRCLE, or the heel, is the round portion of the cam lobe. This is where the lifter rides while the valve is closed. A high spot in this area is called BASE CIRCLE RUNOUT. If the runout is more than .001" on hydraulic lifter cams the valve will be off of its seat while the lifter is on the runout area. Poor performance and burnt valves will result from this. SMALL BASE CIRCLE CAMS have the lobes ground down to the core diameter to give extra clearance for connecting rods used on stroker cranks. Higher lift cams also have smaller base circle diameters than stock lift cams.
    BILLETS and CORES are the blank shafts that the camshafts are made from. CAST CORES and PROFERAL IRON BILLETS are used for most flat tappet camshafts. STEEL BILLETS are used for roller tappet camshafts.
    CAM LOBES are the parts of the camshaft that create the valve movement.
    CAM PROFILE or CAM GRIND is the actual shape of the cam lobe.
    CHILLED IRON LIFTERS are heat treated by pouring the molten alloy into a mold that has a chilled steel bottom plate. They are compatible with steel and hardface cams only.
    CLEARANCE RAMPS are the portion of the cam lobe between the base circle and where the valve starts to open. They slowly take up any slack in the valve train and reduce the shock created by the sudden movement of the lifter.
    CORE DIAMETER is the diameter of the camshaft measured between the cam lobes.
    DUAL PATTERN CAMSHAFTS have different intake and exhaust lobes. There are various opinions on whether or not there is an increase in performance over a single pattern camshaft. Unfortunately there is no fair way to compare the two styles. Both types work quite well and there is no benefit to turning down one style of camshaft in favor of the other on this basis alone.
    FLANKS are the sides of the cam lobe that cause the movement that raises and lowers the valve. They are also called the OPENING and CLOSING RAMPS.
    HARDENABLE IRON LIFTERS are high quality lifters compatible with cast and proferal billet cams.
    HARDENING is achieved by heating the cam and quenching it in oil to give durability. FLAME HARDENING and INDUCTION HARDENING are two methods used. Typical hardness for flat tappet cams and lifters is Rockwell 32C.
    HARDFACE OVERLAY is used in highly modified race engines when a very hard solid lifter cam is required. Chilled iron lifters must be used on hardface cams.
    NOSE of the cam lobe is the portion of the lobe with the highest lift. The nose of the cam should be .010" shorter than the bearing surface on a V8 or V6 camshaft except on small base circle cams.
    PARKERIZING is the application of a special high quality oil-absorptive coating to the surface of the camshaft. This protects the cam lobes during break-in.
    PRELOAD is the type of adjustment for hydraulic lifters. When the clearance is removed from the valve train the rocker arms, or adjustable pushrods, are tightened an additional turn to "preload" the hydraulic lifter.
    PUMPUP happens in stock hydraulic lifters at high rpm. They simply can't handle the volume of oil and the extra operating speeds so they expand, or pumpup, causing the valves to stay off their seats slightly even while the lifter is on the base circle of the cam. Anti-pumpup lifters reduce this problem and Rhoads Variable Lifters eliminate it altogether.
    RATE OF LIFTrefers to the speed that the valve opens and closes. Cams with a higher rate of lift have more lobe area to provide performance gains. Cams with an extremely high rate of lift require mushroom lifters.
    REFINISHING refers to restoring the cam lobe to its original shape (except slightly smaller) when there is only minimal wear.
    REGRINDING is the work of restoring a cam with alot of wear or altering a stock cam to performance specs. Both refinishing and regrinding require precision equipment and master lobes.
    SPLIT OVERLAP is the term used when the piston is at top dead center and both the intake and exhaust valves are off their seats the same amount. With a single pattern cam this would mean that the camshaft was timed straight up. Advancing or retarding the camshaft will open one of the valves more at top dead center and reduce the valve to piston clearance.
    VALVE FLOAT happens when the speed of the engine is too great for the valve springs to handle. The valves will stay open and/or "bounce" on their seats. The clearance in the valve train created by valve float will also cause hydraulic lifters to "pumpup" as they try to eliminate the valve clearance.
    VALVE LASH is the amount of clearance, measured at the valve, in the valve train when using a solid or roller camshaft.
    VALVE TRAIN is the "train" of parts leading from the cam lobe to the valve.
  8. #33
    Default fpr
    hookecho where did you get your adjstible fuel pressure regulator.
    I am doing my own n/a build just looking for input
  9. #34
    ^^weapon R
  10. #35
    Quote Originally Posted by hookecho
    Good read, that needs to be stickied somewhere.
    Quote Originally Posted by Murgatroy
    It is. In this thread.
  12. #37
    hookecho i also would like to know where you got the metal head gasket and your arp studs?is you FPR universal or made for the 5s
  13. #38
    You can use the metal head gasket from the late 90s (97-99IIRC) Celicas.
  14. #39
    the head gasket gasket i bought off ebay, you can buy the oem one for a 97+ camry/w 5sfe as those were metal hg. the ARP studs came from ARP. they don't make any specificly for the 5sfe so you'll have to buy the ones for the 3sgte. they'll work just fine. the fpr is universal.
  15. #40
    here is the flow chart for the before and after of a port & polish.
    this is the stock 5sfe head flow chart.
    Toyota 5S-FE cylinder head flow test
    Flow testing: 28 H2O
    Intake: 1.260 head diameter 6mm stem
    Stock valve angles
    Stock valve seat angles & width
    Stock port with clay radius inlet
    Valve Lift/ Flow (CFM)
    .100 / 83.58
    .200 / 157.21
    .300 / 180.56
    .400 / 183.52
    Exhaust: 1.063 head diameter 6mm stem
    Stock valve angles
    Stock port straight out (no pipe)
    Valve Lift / Flow (CFM) / % of intake flow
    .100 / 64.66 / 77.5
    .200 / 108.16 / 69
    .300 / 124.60 / 69
    .400 / 126.88 / 69
    Toyota 5S-FE cylinder head flow test After light port & polishing
    1mm larger valves
    Intake valves: 33mm (head diameter) X 97.5mm (stem length) with a 6mm diameter stem
    Exhaust valves: 28mm (head diameter) X 98.5mm (stem length) with a 6mm diameter stem
    Intake: 1.300 head diameter 6mm stem
    Light port work, seats machined with 5 angles
    45 Seat
    radius inlet
    Valve Lift / Setting1/ %2 / Flow (CFM) / Gain (CFM)
    .100 199 46.5 3.58 8.95
    .200 / 199 / 86 / 157.21/ 13.93
    .300 / 296 / 70.5 / 180.56 / 28.12
    .400 / 296 / 72.5 / 183.52 / 31.08
    Exhaust: 1.100 head diameter 6mm stem
    Light port work, 3 angles & radius on seat
    45 Seat
    Valve Lift / Setting1 / %2 / Flow (CFM) / Gain (CFM)
    .100/ 106 / 63 / 66.78 / 2.12
    .200 / 208 / 55 / 114.40 / 6.24
    .300 / 208 / 66.5 / 138.32 / 13.52
    .400 / 208 / 70 / 145.60 / 18.72
    Notes:
    1 The setting value refers to the maximum flow setting on the flow test machine
    2 The percent is the amount of the maximum flow setting that was used for the test (For example, Setting = 300 cfm, % was 50, then the actual flow used to test would be 150 cfm)
  16. #41
    Mar 2005
    so whatever happened to that thread you promised to make , the one about the ats thread/
    2012 Jeep Wrangler
    1993 Mr2 Turbo
    Originally Posted by vangls14
  17. #42
    Great work hookecho!
    I have always been a fan of N/A power and I actually am planning a high rpm high output v6 for my mr2 setup as well as a mildly modified 1uz setup for my tacoma. N/A is great!
    As for the 5s stuff, i have several heads here that i am looking at improving flow and developing my own head upgrades for people (see the other cams thread near this one). In the spring of 08 i hope to work closely with Geoff at colt cams (he is local to me) to develop several different cam profiles which include some different cam timing values (built into the grind) and implementing his new Tri-Flow design.
    To add to this thread:
    For 4a-fe people the pre 93 4a's also have a much smaller cam lobe size and different profile (dont have numbers at the moment as i left my notebook at colt cams). So similar results can be achieved going to a 93+ 4afe cam in the pre 93 4afe motors. I personally swapped in a 95 4a-fe into my 92 All-Trac Corolla due to the fact it is a bit better of a motor and puts out a wee bit more power.
    I am also going to be making a set of stock diameter higher flowing valves from manley performance. They have the stem diameter reduced on the stem portion exposed to the intake/exhaust tract, this in turn increases airflow by as much as 93% (exhaust) or 43% (intake) at .100" lift, the improvement goes down as the lift is increased (12% intake 22% exhaust at .300" lift).
    I will also test out the 3s/jz ones to see if the 1mm o/s will add even more flow to the setup.
    -Johnny
    New site is up!
  18. #43
    i know this is kinda off subject but it says you have the fastest N/A gts, do you have any time slips, also where can i get the adj cam gears
  19. #44
    i don't drag race my celica so i have no time slips. it's not meant to be taken seriously. AEM makes a cam gear. the one for a 2jz will fit with an adjustment to the mounting hole.
  20. #45
    Quote Originally Posted by Weasy2k
    thanks Weasy, i appreciate the info and am following your work. keep it up and keep us posted.
  21. #46
    thanks hookecho youve helped a lot when my 6th gen is done ill have to post some dyno #s and 1/4 mile times
  22. #47
    Mar 2005
    when are you planning on getting your 5s dynod?
    2012 Jeep Wrangler
    1993 Mr2 Turbo
  23. #48
    Quote Originally Posted by burnyd
    after i install these 3s valves and standalone. which will probably be after i get out of the police academy. idk of a chasis dyno around here so i'll probably have to drive to memhis.
  24. #49
    i have my build up started heads at machine shop goeff has my cams
    i should have my dyno #s in a few months
  25. #50
    You have the 93 or 91 cams? I saw 2 sets there.
    -Johnny
    New site is up!
  1. List of 7th Gens.
  2. Head gasket (maybe piston ring?) issues
    By Disco Dan in forum Maintenance, Troubleshooting, & Repair
    Last Post: 09-07-2008, 08:10 PM
  3. 7a-gte??
    By Chris_95geo in forum Custom Engineering/Design/Fabrication
    Last Post: 05-07-2007, 04:07 PM
  4. Get it right the first time... Save money. 3SGTE build discussion.
    By BlueDragon in forum Forced Induction Applications and Tuning
    Last Post: 10-28-2005, 06:14 AM
