    Chicago, IL
    Default sticking throttle cable
    My throttle seems to be sticking. Everytime I'm just driving regulary it won't return all the way to closed so the revs will stay up there on downshifts and slowly fall. And If I put the clutch in, it doesn't go to idle but to around 2000rpm. If I jab the throttle to WOT and quickly let go, the throttle closes completely and it idles normally. It looks like the cable isn't letting the throttle close all the way or the return spring on the throttle isn't strong enough. I messed with the throttle in the engine bay and it closes properly but if I use the pedal inside the car it will stick.
    Is there any way to make an adjustment so it closes completely? Should I lube the cable somehow? :luvydunno Can I make the spring act stronger so it can close completely?
    There's probably a simple solution I'm overlooking since I'm really tired right now. Help me out
    Thanks
    '90 Celica GT
    '95 Miata
    Chicago, IL
    Looks like it's going to be the throttle cable that goes from the gas pedal to the cruise control thing. Just a follow-up so people that dig this thread up through the search later on won't be wondering what it was.
    '90 Celica GT
    '95 Miata
    I guess it is possible the cable is suddenly adding too much friction, but I found that the return spring or some portion of it will somehow unhook so there is not enough force to close the throttle plate. If the throttle body is really dirty it could also add some friction or keep it from closing occasionally. I think it is more likely the return spring on the throttle body. Take a close look and make sure all three spring wires are hooked up on the throttle body.
  1. Throttle Cable Question
    By 1EXQUIZITCELICA in forum Maintenance, Troubleshooting, & Repair
    Last Post: 12-19-2006, 02:18 PM
  2. 7th Gen. Tighten Throttle Cable
    By bolistik in forum General Discussion
    Last Post: 07-25-2006, 12:51 AM
  3. throttle cable sort of...
    By Bitter in forum 6th Generation
    Last Post: 11-12-2005, 01:08 AM
  4. 3sgte into at-200, throttle cable question
    By bongbbreakin in forum Forced Induction Applications and Tuning
    Last Post: 07-06-2005, 05:07 AM
  5. throttle cable
    By dman in forum Maintenance, Troubleshooting, & Repair
    Last Post: 12-27-2004, 08:18 PM
