Results 1 to 8 of 8
Thread: Fog Lights
    Default Fog Lights
    I purchased a OEM fog light switch and threw a relay in my Celica after I ordered actual fog lamps from someone on this board. Well, I figured they just went in the front bumper, but after closer examination, you need special holes in the bumper for fog lamps. :duh:
    Now I have 2 lamps here that I don't have cutouts in my bumper for. I already have the switch and everything in, and I was planning on using these as DRLs and extra night visibility moreso than as fog lamps.
    :brick:
    I'm thinking about buying some aftermarket driving lights or something that can easily be mounted in the vent holes in the front of the bumper. Does anyone here have any suggestions as to good ones that will fit well and look good? They can't be too big, because I want to still use stock wiring, and I'm not sure how much juice the stock wiring for it can hold up to.
    Chicago, IL
    Not sure if I understand your problem, if you have the 1990 bumper they go right in. You don't need to cut any plastic part of the bumper, it mounts to the metal. Did you buy the 90-91 fogs? Do you have the stock bumper?
    Pardon the salt/dirt, this was taken during the winter. Your bumper should be the same as mine.
    '90 Celica GT
    '95 Miata
    Interesting, that looks like my bumper, but I didn't see the mounts for my passenger side one. The bumper has been replaced as the previous owner got backed into.
    So maybe they will fit in, I'll have to go look more carefully.
    Chicago, IL
    passenger:
    driver:
    '90 Celica GT
    '95 Miata
    Also, do you happen to know what size bolts those are? The fogs didn't come with them, so I have to source my own.
    [edit]
    Yup, just went outside and saw the bolt holes. Sweet!
    Chicago, IL
    Sorry, no idea
    '90 Celica GT
    '95 Miata
    10 or 12mm
    Originally Posted by vafalla
    Thanks.
  1. lights wont turn off!!!!!!
    By jjazmin in forum Electrical, Audio & Security
    Last Post: 01-22-2007, 06:15 AM
  2. Fog lights help
    By splinter182 in forum Electrical, Audio & Security
    Last Post: 01-07-2007, 04:03 PM
  3. Pictures of new fog lights
    By st184-r in forum Multimedia Forum
    Last Post: 12-16-2006, 04:07 AM
  4. 3sgte swap done, but now headlights and parking lights dont work...help!!!
    By bongbbreakin in forum Forced Induction Applications and Tuning
    Last Post: 05-10-2005, 05:35 PM
