Results 1 to 13 of 13
    Default plugs for the nitrous baby?
    3SGE uk stock 147 bhp,133ib/ft@4800rpm. ive dyno'd at 145bhp.
    stock header and fueling.
    current mods, full free flow custom 3inch zorst, no cat. cone filter and intake pipework, fifty hp wet nitrous kit - dyno'd at 205bhp at 6500 rpm.
    to be done - 1.2mm TTE MHG, performance clutch, up jets to 75hp.
    as well as ignition timimg adjustment for knock, what plugs would you use? expecting at least two thirty horses under full throttle at 6500 rpm under the gas.
    and we run 98ron super in the uk.
    Now playing with;
    Ultimo Miembro Fantįstico Gigantesco ChrisD has much to be proud of ChrisD has much to be proud of ChrisD has much to be proud of ChrisD has much to be proud of ChrisD has much to be proud of ChrisD has much to be proud of ChrisD has much to be proud of ChrisD has much to be proud of ChrisD has much to be proud of ChrisD has much to be proud of ChrisD's Avatar
    http://www.celicatech.com/forums/showthread.php?t=293
    copper plugs, one range colder than stock.
    can you look in your owner's manual and give me the NGK or Denso part number for your stock plugs for that specific motor
    and i will look it up and give you back the part number for the plug you need
    thx
    2005 C200 Kompressor sport
    my blog:
    Why you installing a thick HG?
    Loopy
    NGK BKR7EIX on 50hp BKR8EIX on 100hp BKR9EIX on 150+hp
    You could go to the full race plugs NGK R7435-8 but at £25 a pop and a short life keep them for special occasions
    Gap them to about 0.8mm and if its still not lighting then its either too rich or the coils on its way out, stick with Stock Mr T coil, its a good one.
    iridium ? hrm
    my blog:
    Loopy
    Yeah, i know there are all sorts of rumours about Iridiums versus Coppers.
    I'm an ex Copper fan myself. Times change and things move on.
    As long as you can find the same sort of grade they work a lot better, last well and can actually take a bit of stick.
    Supprisingly the BS about a stronger spark seems true, they'll light what a copper can't.
    There's a LOT of R&D gone into Iridiums over the last few years whereas development and even production of standard coppers is being phased out (and that came from NGK themselves)
    Put it this way, 100% nitrous power gain, over 100lb's of gas on this set of 9's
    Quote Originally Posted by whtcelionteins
    i'm not, and realise why.
    thanks for the replys guys.
    Glad to see you aboard Loopy.
    Now playing with;
    what engine are you running loopy, and thank you for sharing !
    -nuke
    my blog:
    ST182 rev 2 UK SPEC 3SGE iirc, c'mon loopy get some pics up of the Wizards of Nos motor.
    Now playing with;
    Loopy
    '93 ST 182
    120,000 miles (av 8% leakage)
    K&N induction filter.
    Home brewed 2 1/4 mandrel exhaust.
    Magnecor KV85's
    95 octane (4 deg retard for the gas)
    Walbro 225 fuel pump
    FSE FPR
    The rest is totally standard and box stock.
    Well, apart from this;
    A Wizards of NOS Streetblaster 150hp direct port, running full race progressive controller and 11lb bottle (ARC heated)
    + Co2 Fake purge kit
    I'm trying to find any info on what the stock pistons are meant to take before i up the spray further.
    12 years on and she still stops people in their tracks (and scares Scoobies)
    nice but i'd put a bigger exhaust on there for 320hp !
    you're redicoulous man
    powered by toyota
    my blog:
    Loopy
    2.5" cost it too much off spray performace, even for me.
    2.25" mandrel, no cat and two straight through boxes was a compromise that kept its manners (just) and hasn't become limiting yet.
    (i forgot, i ported out the standard manifold a little)
  1. i cant remove the spark plugs
    By skreem in forum Maintenance, Troubleshooting, & Repair
    Last Post: 11-29-2005, 07:02 AM
  2. Injector plugs
    By chaRwie in forum Australia , New Zealand and Pacific Countries
    Last Post: 02-05-2005, 04:31 AM
  3. FYI on venom nitrous kits
    By nuclearhappines in forum Forced Induction Applications and Tuning
    Last Post: 02-02-2005, 05:24 AM
  4. Nuke's Nitrous Notes
    Last Post: 12-03-2004, 09:14 PM
