Results 1 to 6 of 6
Thread: Auto to stick
    Default Auto to stick
    I have a 2000 GTS that is stuck in park. In the worst case scenario and I need a transmission at only 92K is it an option to change to a manual transmission without a major overhaul? Will stuff bolt in?
    I love the plastic trannys in 2000+ celicas
    Mar 2006
    IL
    Yea, if you get 6 Speed GTS tranny, it will bolt right up. Im guessing you'll prolly need a new ECU for a manual transmission, not 100% sure, but i know the thing will bolt right up.
    2000 Subaru Impreza 2.5RS
    CelicaTech Supporter TheNefariousOne is a glorious beacon of light TheNefariousOne is a glorious beacon of light TheNefariousOne is a glorious beacon of light TheNefariousOne is a glorious beacon of light TheNefariousOne is a glorious beacon of light
    TheNefariousOne has donated to the forums!
    Jul 2005
    NE Philly
    It's gonna require a lot of work (and probably money considering that the 7th gens are still fairly new), but I'm sure it's doable. I doubt your auto is done for though...probably just a bad lever or cable or something.
    It's not really feasible that your car is stuck in park. All 'park' is is a pawl that sits in some grooves in a shell. Other than that, the trans is effectively in neutral. But like Nefarious said, it sounds like it's a shift cable or lever. Make sure to check around the shifter assembly on the trans for debris. I've found stones blocking arm movement on several occasions before.
    I am really Embarrassed at this. The new cold air intake prevented the linkage from moving. I had no idea it was in the front like that. Moding to a short intake corrected this. Is there a cable adjustment for this linkage somewhere?
  1. Auto Body Components Info Thread
    By AllOutRed90 in forum Interior/Exterior Aesthetic Modifications
    Last Post: 12-16-2010, 06:39 AM
  2. Auto shift kits and strong auto trans
    By supershannon77 in forum General Discussion
    Last Post: 01-27-2007, 01:08 AM
  3. Auto powered ST183 with 3SGTE help please
    By carlosfandango in forum Forced Induction Applications and Tuning
    Last Post: 05-28-2005, 08:07 PM
  4. Detroit Auto Show Preview
    By medivh66 in forum General Discussion
    Last Post: 12-20-2004, 08:29 PM
