Results 1 to 25 of 31
    Default Wheel/tire combo fitment (all generations/body styles)
    So... in my boredom I have decided we need to keep a list of wheel tire sizes that fit all of our cars. Please only contribute if you have actually installed the combo on your car, no theoretical posts please. Also, if possible, please post pictures of front/rear profile of the car, and side profile of the car. If you have any reason for tire sizing, please post it as well. If you're curious about picking size tires for your wheels play around with the 1010tires.com Tire calculator it will take a lot of the guess work out of speedometer changes, physical size differences of tires. Keep in mind that some tires just run wide, like Dunlop Dirreza Z1 StarSpecs (215 is as wide as other manufacturers 225).
    List the following:
    Your car year, trim
    Related modifications (springs, rolled fenders, spacers)
    The wheel manufacturer diameter, width, offset
    Tire brand, model, size
    Any fitment issues/Reason for tire size
    Example:
    1991 Toyota Celica GT Coupe
    Toyota TRD 6th Gen lowering springs + Koni Yellow struts
    7th gen GTS 16" wheels
    Continental ExtremeContact DWS 195/50R16
    195/50R16 gives +0.86% diameter increase for near perfect speedometer readings on GT
    First Gen:
    Information needed.
    Second Gen:
    Information needed
    Third Gen:
    1985 Toyota Celica GT-S Liftback
    The 28 year suspension mod (~" drop due to age), Kaminari Ground Effects
    XXR 522, 16x8 +0
    Goodyear Eagle ZR45, 245/45/R16
    Slight rub on inner wheel arch, no rub after a little trimming, speedometer near perfect, +.05" increase in tire diameter (+.2%)
    Fourth Gen:
    1987 Toyota Celica GT hatch
    90-93 Megan racing coilovers, rolled fenders, drop guesstimate 5", camber bolts
    Drag DR-41 Front: 15x7+40 Rear: 15x7+10
    Firestone (unknown) 185/55R15
    1988 Toyota Celica All-trac
    Megan Coilovers, Toyota crash bolts (camber -1 in all four corners), rear fenders rolled
    Enkei RP03 17x8 +35
    Direzza Z1 StarSpec 215/40/17
    Fifth Gen:
    1990 Toyota Celica All-trac
    Tien coil overs (approx 1/2" drop), rolled rear fenders
    Enkei RPF1 17x8+35
    Falken AZENIS RT615K 225/45R17
    1990 Toyota Celica ST Coupe
    Megan coilovers (approx 3" drop)
    Drag Wheels DR9 17x7 +40mm
    Kumho Exsta AST 215/40R17/HankookVentus V12 215/40R17
    Enkei RS6 17x7 +38mm
    Toyo Proxes FZ4 205/40R17/Toyo Proxes 4 205/40R17
    Eibach Sportline springs + KYB Struts
    MSR Type 190 17x7 +40
    Kumho Excsta AST 215/40R17
    Eibach Sportline springs + Koni Yellow struts
    Dunlop Direzza Z1 StarSpec 215/40R17 (These apparently run +10 wide)
    Slight rubbing on hard turns (camber corrected this)
    1991 Toyota Celica GTS
    Stock springs/struts
    1992 Toyota Celica Convertible
    Stock suspention
    Stock 7th gen 15 inch rims 15x6.5
    Yokohama S Drive tires 205/55/15
    No rubbing issues
    1992 GT-S
    Suspension Techniques springs (~1.75" drop) KYB struts (stock shape/size)
    Motegi MR-7, 16x7, et unknown but high
    Kuhmo Ecsta Supra 712 225/45R16 fit with lots of room
    Kuhmo Ecsta SPT 225/45R16 fit with lots of room
    1992 GT-S
    Enkei RPF1, 17x8 +45 (fit in front, touches rear strut 5mm or higher spacer recommended)
    Kuhmo Ecsta SPT 245/45R17
    1993 Toyota Celica Convertible
    Stock springs + KYB Struts, GTS front fenders, rolled rear fenders
    Enkei RPF1 17x8 +35
    225/45R17
    Sixth Gen:
    1994 JDM GT-Four ST205
    Stock TRD suspension
    Rota Grid 17x8 +35
    General G-Max AS-03 - 215/45/R17
    Front is quite flush, rear slightly recessed
    Seventh Gen:
    Information needed
    90-93 megan racing coilovers
    drag dr-41's (front 15x7/40) (rear 15x7/10)
    firestone cheaps.......185/55/15
    rolled fenders (but im lowered like 5 inches)
    OREGON TOYOTA OWNERS CLUB LEADING MEMBER
    1988 alltrac
    Megan coilovers
    Enkei RP03 17x8 +35
    Direzza StarSpec 215/40/17
    Full roll in the rear
    215/45/17 gives 0.3% diameter increase for near perfect speedometer readings on ST165
    Chris, that is for the RP03, right?
    Also... what's with the lack of following the example?
    forgot im also running crash colts for -1 camber
    1992 celica convertible
    stock supention
    stock 7th gen 15 inch rims 15x 6.5
    yokohama s drive tires 205/55/15
    no rubbing issues/ wanted a wider tire with a good amount of grip and i got it
    R.I.P Cherry Bomb (1990 Celica ST)
    They call me Hadoken because im DOWN RIGHT FIERCE
    As flatliner pointed out, camber also matters.
    _
    Quote Originally Posted by METDeath View Post
    1992 GT-S
    Enkei RPF1, 17x8, ET45 (?)
    Kuhmo Ecsta SPT 245/45R17 fit in the front, but rear barely touch the stock struts. 5mm spacer should correct this.
    Lifetime Member Demz is just really nice Demz is just really nice Demz is just really nice Demz is just really nice Demz is just really nice Demz's Avatar
    Demz has donated to the forums!
    Kalamazoo, MI
    Third gen: information needed eh?
    XXR 522, 16x8, 0 offset
    Slight rub on inner wheel arch, no rub after a little trimming, speedometer near perfect, +.05" increase in tire diameter (+.2%), why? because racecar
    The Stable:
    1985 Toyota Celica GT-S "Celes" because racecar
    1999 Chevrolet S-10 LS "Audrey" because **R.I.P.**
    2000 Pontiac Bonneville SSEi "Suzanna" because family car
    1991 Toyota Celica GT "Eva" because DD **Back from the Dead**
    2006 Chevrolet Colorado "Kylee" because racetruck
    ^Clicky for CarDomain^
    Confirmed the RPF1's are +45 and do not fit in the rear with stock suspension.
    Stock TRD suspension (not coilovers)
    Rota Grids (Hyper Black) - 17x8 ET35
    Front is quite flush, rear could poke out a little more in order to be flush with body (unsure of how much of a spacer you'd need)
    Well, fully updated the thread (I think). Also, Chris, I know you got lots of 6th gen fitment information.
    I have all the offset info for both flush and stanced wheels on the 6g, but it's more like a guide than what you are requesting as formatting.
    Abby was setup as follows:
    1996 GT Hatch
    Megan coilovers
    Eibach camber bolts (camber -1 in front, -3.5 rear)
    OEM Mitsubishi Lancer wheels 18x7 +46
    (25mm spacer adapters brought the overall offset down to +21)
    Essentially 18x7 +21
    Federal SS595 215/40/18
    Full roll all around (focus on the front of the wheel arches in the rear)
    215/40/18 was a big tire, it threw the speedo off by about 6-8%
    I drive mostly highway, so I didn't really bother me.
    Featuring Chaos, the Wendigo Celica Murgatroy has a reputation beyond repute Murgatroy has a reputation beyond repute Murgatroy has a reputation beyond repute Murgatroy has a reputation beyond repute Murgatroy has a reputation beyond repute Murgatroy has a reputation beyond repute Murgatroy has a reputation beyond repute Murgatroy has a reputation beyond repute Murgatroy has a reputation beyond repute Murgatroy has a reputation beyond repute Murgatroy has a reputation beyond repute Murgatroy's Avatar
    I updated your shit just for giggles.
    You did it wrong, but w/e.
    1991 Toyota Celica GT-S
    Eibach ProLine (~1.5" drop) KYB struts (stock shape/size)
    7th Gen 16"x 6.5" Wheels
    Yokohama S Drive 205/55/16
    Hankook Ventus V12 Evo 225/50Z/16
    No rubbing issues
    1994 celica gt hatch
    15x6.5 7th gen celica rims
    kyb struts with eibach sportline spirngs. (1.5 inch drop)
    tires are 205/55/15 yokohama s drives
    i would recomend some kind of spacer in the rear, the wheels look sunken it
