    Default 1st gen 5sfe camshaft specs ... is this new info?
    "This is an O.E. Replacement. .273" Intake cam lift, all durations measured at .050", 196 degree intake duration. We do have the Exhaust camshaft in our store. The item number is 7927889273, The cam number is 229-2339"
    http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WD1V
    I looked up the other item they list and i got this :
    NOTE: .299 EXHAUST CAM LIFT 209 DEGREE EXHAUST DURATION.
    http://cgi.ebay.com/ebaymotors/ws/eB...tem=7927889273
    don't know if i believe this ... if i do then this says the 4a and 5s/3s heads share the same cylinder spacing ? dunno really what to think...
    what do you guys think ?
    -nuke
    2005 C200 Kompressor sport
    my blog:
    BiscutWheels
    I called webcamshafts.com to ask some questions... here is what I got.
    The 5S-FE has three lobe prifiles that they have seen.
    1993 MR2:
    Intake: lift = 0.319" duration @.050" = 194 deg
    Exhaust: lift = 0.319" duration @.050" = 200 deg
    1991 Celica
    Intake: lift = 0.290" duration @.050" = 202 deg
    Exhaust: lift = 0.300" duration @.050" = 210 deg
    Another 1993 engine not sure of the car.
    Intake: lift = 0.319" duration @.050" = 200 deg
    This would explain some of the different horse power numbers seen over the years. They also carry a grind for our car if someone wants to turbo their 5S-FE.
    I would think that the 3S-FE and the 5S-FE heads are almost identical. Now the 4A-FE... I wonder about that, I would need to see the heads apart to confirm if they heads are that similar.
    Nate
    Thank you nate
    Web cams for comparison:
    294 Grind:
    322 lift on both
    Duration: 218 @.050
    577 Grind:
    330 lift on both
    Duration: 226 @.050
    101 Grind:
    350 lift on both
    Duration: 228 @.050
    my blog:
  1. Throttle Body Info
    By Schmleff in forum Naturally Aspirated Applications and Tuning
    Last Post: 12-17-2008, 10:44 PM
  2. 5sfe stage 1 turbo kit
    By BEAMS in forum Forced Induction Applications and Tuning
    Last Post: 11-26-2007, 04:18 AM
  3. 3sge ECU for a modified 5sfe ?
    By nuclearhappines in forum Naturally Aspirated Applications and Tuning
    Last Post: 01-11-2005, 03:33 PM
