    Default Question about battery relocation
    In most tutorials I read on battery relocation it shows the negative cable going to the body of the vehicle. When I talked to my brother he said the battery needs to be grounded to the alternator. Am I missing something or is my brother an idiot?
    This car has been sold once, then repossessed then stolen by the same guy 3 times. Yet I still have it
    There are multiple ground points. One goes to the transmission, a smaller to chassy, etc. I know grounding kits have even more, stock has two or three.
    ground travles through metal. if you get a good ground to the chassis in the back of the car, it will travel through the whole car, as long as there is a ground wire up front that goes from the car to the engine your fine. I would redo a couple ground wires get some 4 gauge and some 8 gauge take a 4 gauge from the battery in the back to the car to a good solid bolt nearby you want this wire to be as short as possible dont have it 4 foot long. then take a piece of 4 gauge up in the engine bay from the car to the tranny then a piece of 8 gauge from the tranny to the head. that should be all you need.
    Your brother's an idiot.
    Also make sure that you install a 150amp fuse right at the battery terminal so that if you have a short, you don't light your car on fire.
    -Doc
    -Dr Tweak, Toyota engine swap wiring expert extraordinaire
    The battery to body and trans to body alone are not fine. I had a 1.5v drop form battery to my distro block upfront until I also ran an additional ground from the neg terminal on the batt to the engine. Gain of 1.5v from that! The unibody in the 5th gen celica does not provide a good ground main ground.
    2007 Mazda RX-8 GT
  1. Elliott's intake and battery relocation - You too can attempt this!
    By Elliott in forum Australia , New Zealand and Pacific Countries
    Last Post: 08-12-2006, 09:33 AM
  2. How to: Rear battery relocation (56k warning)
    By Classique71 in forum Australia , New Zealand and Pacific Countries
    Last Post: 02-27-2005, 07:31 AM
  3. Battery question
    By Adam in forum Electrical, Audio & Security
    Last Post: 01-14-2005, 12:56 AM
  4. Project Battery Relocation - Step-by-Step How-To
    By -==L=a=N=c=E==- in forum Australia , New Zealand and Pacific Countries
    Last Post: 12-19-2004, 12:06 AM
  5. Battery Relocation 101 by Conrad_Turbo
    Last Post: 12-01-2004, 11:25 PM
