    Default Check engine code help
    5 fast flashes and a pause and then 1 flash
    so
    11111_1
    Please advise, thank you
    There is no code 51. You screwed up, do it again.
    Well, it could be this:
    Switch condition signal
    Displayed when A/C is on when TE1 and E1 connected in test mode
    -Dr Tweak, Toyota engine swap wiring expert extraordinaire
    that code is also displayed when you hit the accelerator pedal with those terminal jumped.
    1990 Celica ST w/ 4A-FE engine and manual tranny. Chassis AT-180. Magnaflow Cat, Custom built MSD 8.5mm Super Conductor wires, Silverstone S3F Sparkplugs, 1992 GT Coupe Taillights.
    1986 Toyota Supra Liftback w/ 7M-GE and 5-Speed Manual. K&N Drop-in Air Filter, Hella 200mm ECE Headlamp Conversion w/Sylvania Silverstars, Sony X-Plod Head Unit.
    No touching of the throttle.. Engine was on.. could be misadjusted TPS??
    If that's the case then I don't know what is wrong.. this thing is bad.. It's idling down around 600 and when I let off the gas it drops down to 400RPM and then recovers to around 600... it's running like crap. Any idea's guys? For now I opened the throttle by-pass valve screw to up the idle..
    Code 41 is the TPS I think, could it have been 41?
    I don't know.. I unplugged TPS tonight and went for a drive.. it drove no different unplugged.. I popped it apart and the thing has 3 stupid contacts inside it's either on or off.. I don't know.. people tell me i drop a lot of dark smoke out when I romp on the gas too.. and the fumes at idle are strong... Also I think i need new conrod bearings.. pretty sure of it actually
    Well, considering one of the possible problems causing code 51 is a bad TPS idle circut, you might have a bad TPS.....
    Even though it checked out.
  1. Engine Swap Wiring Secrets REVEALED!
    By Dr Tweak in forum Custom Engineering/Design/Fabrication
    Last Post: 01-12-2014, 11:09 PM
  2. 3sgte CEL Error Code List
    By Lagos in forum Forced Induction Applications and Tuning
    Last Post: 09-22-2005, 06:15 PM
  3. Check engine light code
    By Hyper in forum 5th Generation
    Last Post: 07-27-2005, 07:06 PM
  4. Rear main Seal on my 5s (help needed)
  5. Replies: 3
    Last Post: 04-17-2005, 04:56 PM
