Results 1 to 9 of 9
    Talking Elliott's intake and battery relocation - You too can attempt this!
    I actually attempted a not-so-hackjob (its still pretty dodgey) intake and battery location today:
    The new straight intake
    Note the PCV pipe
    Also, dont worry that AFM wireing job is temporary
    The battery relocation done with almost-proper components.
    Parts used:
    $7 battery base from Repco
    $10 rubber 3" to 3" piece from Repco
    $30 dry filter intake from Repco
    $6 aluminium pipe (50cm x 80mm cut down to about 20cm) from Capral
    for the turbo to the aluminium pipe i used a cut down piece from the OEM intake, which works fine.
    Yes, i'm stingey.
    Elliott
    Senior GT2 Member Aust162 is on a distinguished road Aust162's Avatar
    Aust162 has donated to the forums!
    Victoria, Australia
    hrmm... good work getting it all going.i see you did Richard's technique on the battery bracket. that AFM wiring is troubling to see thou.lol. hows the car run? any different? i've heard it should reduce spool up time and make your intake noise louder??
    Now all you need to do is get some air to that filter. CAI style
    1985 ST162 Celica Sx - 3SGTE SW20 swap.
    Dynoed: 219fwhp @ 13psi (17/3/06)w/wolf3d + 50trim ct26
    *back on the rd 8/2/05
    2001 Yamaha yzf-r6.
    Junior Member tooch is on a distinguished road
    Melbourne, AUS
    I'm itching to do the intake mod to my car, haven't had the bloody time tho! Good to see it's easy, altho I wanted to get a pipe welded up like Richard's one with all the connections and shit.
    Looks good tho
    Member -==L=a=N=c=E==- is on a distinguished road -==L=a=N=c=E==-'s Avatar
    Queensland Australia! Ozzie Ozzie Ozzie Oi Oi Oi
    Nice
    Although, a point of warning. the PCV is just that, a positive crankcase ventilation. It has to have 'vacuum' to work at its most efficient.
    Get yourself an oil catch can, and tap it back into the intake.
    Apart from that, top stuff
    Pure ST185 GT-Four goodness, non swapper
    Crank case ventilation can lick my hairy motherfucking balls, its going to the atomsphere till tehd ay i die
    Basically that piope is going to the left bonnet vent. when im sitting at traffic lights i get an awesome oil-steam pouring out hte bonnet it looks funky
    There was no noticable difference between my old "HKS filter with a stock intake" to the new "straight-pipe with repco intake" in either sound or spool time, but i wasnt expecting anything fantastic - it looks funky though.
    Also i have a 200W 12V fan connected to my air intake pipe to draw up as much cold air up the stock intake pipe as possible - which should at least bring some more cold air into circulation undetr hte bonnet.
    Ignore me ive been drinking.
    Elliott
    Member ROME is on a distinguished road ROME's Avatar
    Melbourne, Australia
    Well i see that the AFM wires need to be extended.. How about the battary wires?? Do they reach to their new position?
    If it can break, I broke it
    The AFM wires needed extending (which i did by twisting the cores together and electrical taping it ), and the only thing i did to the battery wire was move the negative terminal chassis ground.
    Elliott
    Quote Originally Posted by Elliott
    Elliott
    same here.
    IC u've got a bit of the old stock intake tubing there... mind gettin it pointed at the new filter?
  1. Rear main Seal on my 5s (help needed)
  2. Project Battery Relocation - Step-by-Step How-To
    By -==L=a=N=c=E==- in forum Australia , New Zealand and Pacific Countries
    Last Post: 12-19-2004, 12:06 AM
  3. Battery Relocation 101 by Conrad_Turbo
    Last Post: 12-01-2004, 11:25 PM
