    Default Engine vin location?
    Hey guys i've searched and couldn't find any info on this. Is there a vin or engine code on the engine? The only thing i can find is that paper on the timing cover that has some wierd numbers but couldn't make any sense of it. The engine is covered with a lot of grease so I cant really just look and find it. Thanks
    2000 GT-S (Sold) ~~~~~~~~~~~~~~~~~1990 GT-S (Wish it was a Real GT-4)
    Why is there never enough time for the first time But there is always time for a second?
    on the 5sfe the engine serial number is stamped on the left rear side of the block
    sloceli
    The Vin is located on the bottom front right of the block. There is a small plate rivited to the block close to where the transmission brace is attached.
  1. Engine Swap Wiring Secrets REVEALED!
    By Dr Tweak in forum Custom Engineering/Design/Fabrication
    Last Post: 01-12-2014, 11:09 PM
  2. The 3sgte Swap
  3. The use of Engine Flush next time you change your oil
    By MrWOT in forum Maintenance, Troubleshooting, & Repair
    Last Post: 05-04-2005, 05:26 AM
  4. FAQ's: exhaust smoke by LoKi
