  • Non-fog lamp to factory fog lamp conversion *56k warning*
    I figured this would be a good guide for anyone who doesnt have fog lights in their celica to know how to convert them rather than start from scratch. This was done with a 90-91 celica, and due to the bumper style changes of 92-93, I am not sure if they will connect the same way. Same applies for the alltracs, GT-S's, and Carlos Sainz versions. However, the wiring will all be the same, so if nothing else that part will be helpful to all.
    *DISCLAIMER* I nor celicatech.com are responsible for any damage that may occur while performing this upgrade. If any damages do happen to occur, it will be under the responsibility of your own negligent behavior and will be up to you to repair them or have them repaired. In no way shape or form will I nor celicatech.com be held responsible if you find any differences from what you read and what you find, keep in mind this was performed on a 90 Celica GT, and other celicas may vary. Please be cautious when working with electrical items to avoid shock, or damages to the vehicle. Before working, disconnect battery and place outside of vehicle.*DISCLAIMER*
    *Note: Changes may be made at any time
    Parts you will need:
    Fog lamps
    Fog lamp brackets
    Fog lamp switch
    Relay
    Mounting bolts for fog lamps
    Mounting screws for fog lamp switch
    Guide:
    All harnesses and relay are circled in blue
    All bolts are circled in red
    All bold areas are the start of a new section and is the information you need to know first
    Alright, first things first, I know you are going to be like me and want to get the fog lights mounted up so you can see how the car will look, to make it look like this...
    Well it's simple, and only requires 2 10mm bolts per lamp. If you pull the fog lights or are buying them off of someone, demand they include the bolts with the fog light brackets or you will have to go to a junk yard to get them. There are also more than just these 4 holes on the actual bumper (metal), however you will be able to tell which ones they are because they are the only holes with a thread in them. Also, it doesnt require removal of the bumper, just come from underneath it.
    Here is an underside picture of the PASSENGER side fog lamp, and the mounting bolts are circled in red...
    The right hand bolt in the pic is hidden behind the bumper, its a bit of work to get to but possible. The bolt that is half way cut off on the left I took a picture of through the front bumper, it is pretty easy to tell where it is.
    Now that you have them mounted, lets plug in the lamps. This requires removal of your bumper lantern because the harness is tucked up in the fender and taped to the bumper light harness. It is not hard to get to though, so dont worry.
    Here is a pic of where it is located, it will require you to pull it out though because it is tucked in since your car wasnt suppose to have fog lamps...
    You will most likely have to connect the harness up in this area, so do connect this harness to the fog lamp harness before putting your bumper light back in.
    Next thing to do now is mount the fog light switch, which will take a good amount of work.
    You will need to remove your dash trim, 2 screws are located on the trim above the gauge cluster. On the piece right above the steering column (blue in the pic), there are 4 screws on the bottom of it.
    *Note: A lot of my interior is gone, so you will have to do a little bit of extra work than what I am able to list.
    The knob on the passenger side vent will pop off, but takes a good bit of effort, I believe its glued in but not 100% sure. Also dont worry about getting the HVAC controls off as they will not effect your work.
    You will only need to get to this point, and where the switch harness is is circled...
    You will also need to remove this....5 bolts, all circled in red...
    And aha! There it is, hiding under the driver side duct!
    After you find that, pop out the placeholder for the fog light switch. It goes in from the front, so you will need to pop it out towards you by squeezing in the clips from the back. After you do this, you will need to screw in the light switch. There are alignment rods so have the switch in them before screwing the switch in.
    I went to Lowes and picked up these screws, they work perfectly...
    They are only about $1.20 for the pack, and they will hold the switch in securely. They can be found in the droors full of bolts, screws and nuts.
    Now that the hard part is all over, all that is left is inserting the relay. Here is a tip, the relay they recommend is....well I hope you're sitting down...$50-70. But not to worry, I picked up a different kind that worked just as well for $10. It may not be quite as durable, but it gets the job done, and will save you a load of money. I picked it up at autozone, you will need to ask them to get the part, the number is "19456 41-5125". Im not 100% sure, but they may be able to find it with just the 41-5125 part, but you have the whole number that is on the box just in case you need it. If you prefer to have the relay they say you should have but dont want to spend the money, I recommend going to a junk yard.
    Here is the relay and where it mounts up as circled, this is in the kickpanel on the PASSENGER side...
    Well thats all there is to it, so now you should have working fog lights! If you go to push the button and nothing happens, do not worry! Remember to turn the ignition on and your lights on, then they will work.
    Here is what you should get, one happy car
    This article was originally published in forum thread: Non-fog lamp to factory fog lamp conversion *56k warning* started by celicaGT90_05 View original post
  • Recent Forum Posts
    celica91gts
    Oops sorry. It's a s53 tranny mated to a 4th gen 3sgte
    Slipping clutch
    celica91gts 1 Day Ago Go to last post
    4thgenceli
    I'm not seeing a gasket around the input shaft for the St185 model for the blowout I'm looking at. You can ask Lithia and they may be able to help better
    Slipping clutch
    4thgenceli 1 Day Ago Go to last post
    celica91gts
    Thanks for the part number Tim. I probably have my vocabulary for the seal wrong which is why I'm having a hard time finding it. It's the seal that is
    Slipping clutch
    4thgenceli
    The part number for the rear main seal on the Gen4 is 90311-89001. This cross checks to all of the 4th gen and 5th gen Celicas (ST16*, AT180, ST18*) as
    Slipping clutch
    celica91gts
    Brand new clutch got ruined because oil leaked onto it from tranny front seal. I know cuz the gear oil i use is purple. While im at it i will also replace
    Slipping clutch
    celica91gts 2 Days Ago Go to last post
