  • Fog Light Rewire
    After reading some other write up on re-wiring your foglight relay, I decided to do it a different way. It much easier and works better than running a 5' wire under the carpet and wedging it into a fuse, seriously, there are simple wire splice connectors.
    Anyway I wanted mine to be able to come on whenever I want as long as the ignition is on, so first off I looked for a hot wire only when the ignition is on. It just so happened that this wire is hot (has power) only when ignition is on, so it will also be fused.
    You will cut the smaller of the two white wires with red tracers, this wire should only be hot when the low beams are on, that is what tells the relay to turn on.
    I chose to use a sodder/shrink wrap connecter to cover up the other end that you cut to keep it from shorting out. Then tapped the wire that was connected to the relay into the hot wire.
    Wala, fog lights when I want, and if I forget to turn them off, they will still be off if the ignition isn't on! Pics to come soon.
    Relay pulled, cut the small red/white wire
    This is the wire I found to be hot with ignition on
    Here's what it looks like with the wire coming from the relay to the hot wire.
    All done... :thefinger
  • Recent Forum Posts
    Murgatroy
    Ha, it looks like the Corona VX Coupe was the same as the Celica Coupe other than the hood, grill and headlight, even the fenders and bumper look the
    Curren front end
    Murgatroy 13 Hours Ago Go to last post
    fussellbug
    The Corona coupe front end fit the fourth gen Celica and used flush headlights instead of the pop-ups.
    Curren front end
    fussellbug 20 Hours Ago Go to last post
    bloodMoney
    Did you try cleaning the switch contacts? Try jumping the leads directly with a 12V source to see if you can get the motors to activate the other way.
    Convertible top questions
    bloodMoney 4 Days Ago Go to last post
    underscore
    If I remember right there's a non-flip front for the 4th and 5th gens too, I can't remember what they're called though. They make the Celica look too
    Curren front end
    underscore 5 Days Ago Go to last post
    CriScO
    Actually, though I can delete it, it would be more helpful to post your solution. Let us know what it was.
    Sent from my SM-N950U using Tapatalk
    91 celica fog light question
    CriScO 6 Days Ago Go to last post
