  • Power Steering High Pressure Hose Upgrade
    Custom Built PS hose:
    Here's a tip that's not very hard to do and will save you $$ when repairing the Power Steering High Pressure Hose.
    I used a grinder and Dremel tool to remove the old crimps from my leaky OEM PS high pressure hose but retained the factory OEM fittings. Took me a little over an hour or so. Work carefully and try not to cut or grind into the original fittings. I nicked mine a few times but it was still OK.
    Took it to my friendly neighbourhood hydraulic hose shop. They crimped on new ferrules and a higher-than-spec, wire-reinforced hose for only $14, taxes in. Sure beats paying $80 for a jobber hose or $150+ for a weak, non-reinforced Toyota OEM hose.
    Here's how the fittings look disassembled below:
    The hose is double-wire braid reinforced, rated @ 4800 psi.
    Funny, the shop guy realized after he made it that it was a bit of over engineering, but it'll never leak again
    Previously, I've also used the single-wire hose that was rated @ 2600 psi - more than adequate and what I'd recommend because it has a bit more flex.
    End.
  • Recent Forum Posts
    fussellbug
    The Corona coupe front end fit the fourth gen Celica and used flush headlights instead of the pop-ups.
    Curren front end
    fussellbug 44 Minutes Ago Go to last post
    bloodMoney
    Did you try cleaning the switch contacts? Try jumping the leads directly with a 12V source to see if you can get the motors to activate the other way.
    Convertible top questions
    bloodMoney 4 Days Ago Go to last post
    underscore
    If I remember right there's a non-flip front for the 4th and 5th gens too, I can't remember what they're called though. They make the Celica look too
    Curren front end
    underscore 4 Days Ago Go to last post
    CriScO
    Actually, though I can delete it, it would be more helpful to post your solution. Let us know what it was.
    Sent from my SM-N950U using Tapatalk
    91 celica fog light question
    CriScO 5 Days Ago Go to last post
    jman91
    I figured it out. I would delete my post but don't know how. Thanks
    jman91 5 Days Ago Go to last post
